Top-End Rebuild on '76, Starting T-E rebuild on my 66k original miles '76 |
Gatornapper |
Aug 5 2022, 09:09 AM
Senior Member Group: Members Posts: 1,215 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Dropped the engine yesterday and starting to pull things apart - but having internet problems uploading pics.
Putting in AA's new Cylinder Heads & 96mm P's & C's. Can't wait. More pics when I can get uploading to work - downloading is fine.... GN (IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1659712197.1.JPG) |
DRPHIL914 |
Mar 14 2023, 07:26 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Well, 7 months later, I'm making progress. Too many other projects as always including a like new '81 928 that I was not looking for and literally landed out of nowhere in my lap (yes, was looking for one 2 years ago & gave up), and converting my 20' x 25' tractor shed to a new 2-car detached garage. More on that in another thread..... (IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1678783506.1.jpg) Have a critical question. First....... Heads & cylinders off. Heads look good, but getting new ones - if I can find them. AA seems out. One bad cylinder. Top end had been off before, re-builder did not get one circlip set in place on #2 and it wore a groove in that cylinder. New cylinders needed too. Good news is the cams look new and so do the lifters. Original. I want to get the 96mm high compression pistons. I've been working on the D-Jet now off and on for 4 years and all I need is new injectors, hoses, dizzy with ECU points. QUESTION: Can I run the high-compression 96mm pistons with the D-Jet? Can the running mixture be tweaked for the difference? TIA, GN hey there GN! i have the AA heads built for 96's and running the D-jet tuned , running great as you know. if you can find the raw heads have someone build them , dont use the parts that come from AA on them i have heard they are not such great quality. the new castings are available from a lot of venders, otherwise check with Rich i sent you his contact info. - good to see you getting so close to getting that on the road again, you should set a goal to bring it to Okteenerfest in Sept. Phil |
Gatornapper |
Mar 15 2023, 04:20 PM
Phil -
Sorry I missed this - heads already ordered. Decided to take the risk - figured if George sells them they can't be bad. Read critiques about their weaknesses, hope I have no problems. Liked that SS valves & springs are already in place. Tried to order them through Auto Atlanta but AA PP would not respond to their requests, so I ordered directly and had no problem doing so. Not Albert's fault. He tried hard for several days. Missed Rich's contact info.....did you PM it? GN hey there GN! i have the AA heads built for 96's and running the D-jet tuned , running great as you know. if you can find the raw heads have someone build them , dont use the parts that come from AA on them i have heard they are not such great quality. the new castings are available from a lot of venders, otherwise check with Rich i sent you his contact info. - good to see you getting so close to getting that on the road again, you should set a goal to bring it to Okteenerfest in Sept. Phil [/quote] |
Lo-Fi Version | Time is now: 18th May 2024 - 06:25 PM |
