Top-End Rebuild on '76, Starting T-E rebuild on my 66k original miles '76 |
Gatornapper |
Aug 5 2022, 09:09 AM
Senior Member Group: Members Posts: 1,215 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Dropped the engine yesterday and starting to pull things apart - but having internet problems uploading pics.
Putting in AA's new Cylinder Heads & 96mm P's & C's. Can't wait. More pics when I can get uploading to work - downloading is fine.... GN (IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1659712197.1.JPG) |
Gatornapper |
Apr 22 2023, 05:14 PM
FINISHED REBUILDING TRANNY!
With the great help of Rick B all the way, today we finished rebuilding the tranny. Many thanks to Mike Lesniak's great videos, answers to personal emails, Mark Lindner's tools that he rents for a small fee. NEW AND REPLACED: 1st & Reverse Sliding gear, 1st Gear loose, 1 synchro ring for 1st and 1 set of dog-teeth for 2nd gear. About $900. All other parts of the tranny looked brand new. I can't wait to drive the car as much for the tranny as the engine. I had no synchro in 1st gear, and an occasional unavoidable "crunch" going into 2nd, so having those issues gone will be wonderful. Also along the way: new throw-out bearing, renewed faces of flywheel & pressure plate - both looked good. Clutch plate was new from PO thicker than original. Also new front and rear main seals installed. Hoped I could get case cleaner than I did, but it's the best I could do. Some pics along the way after ones above...... (IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1682205294.1.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1682205294.2.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1682205294.3.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1682205294.4.JPG) Cleaned all this area up after pic, so grease & all is gone now.... (IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1682205294.5.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1682205294.6.jpg) Next week - on to putting on new top-end on engine! GN |
Superhawk996 |
Apr 23 2023, 10:35 AM
914 Guru Group: Members Posts: 5,857 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Hoped I could get case cleaner than I did, but it's the best I could do. GN Eastwood makes some really nice polishing kits (IMG:style_emoticons/default/huh.gif) Good job - almost every tranny I’ve taken apart has worn 1st and second gear dogs. Should be much nicer for you now! |
Gatornapper |
Apr 23 2023, 07:33 PM
I first pressure-washed exterior of case, then soda-blasted it, keeping soda out of inside.
GN Hoped I could get case cleaner than I did, but it's the best I could do. GN Eastwood makes some really nice polishing kits (IMG:style_emoticons/default/huh.gif) Good job - almost every tranny I’ve taken apart has worn 1st and second gear dogs. Should be much nicer for you now! |
Lo-Fi Version | Time is now: 25th May 2024 - 09:03 PM |
