ignition switch, no start |
doobie123 |
Aug 5 2022, 04:59 PM
Member Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi all,
just received a new ignition switch from auto atlanta, those guys are great! installed it but still no start. the car will start by jumping the battery to the solenoid with the key in the run position but still wont start with just the key. i should say that i have not put the rest of the steering wheel/ directional switch back together in case it did not work. could this effect it? also it looks like someone before me took the large yellow and yellow/red stripe wire under the passenger seat and hooked them together to bypass the seat belt switch. in addition that relay under the seat and the wires going to it are in bad shape and the mount for the relay has rusted. i'm looking for any suggestions that i could try so please, any help would be great. thanks |
doobie123 |
Aug 19 2022, 01:56 PM
ok so i installed the hot start kit and...nothing changed.
when i turn the key, i don't get power to the yellow wire at the solenoid. also, i don't get power to the by pass wires under the passenger seat when turning the key.i have continuity with the yellow and red striped wire from under the seat to the ignition switch and there is power at the switch. so what do i need to check? |
Lo-Fi Version | Time is now: 18th May 2024 - 03:02 AM |
