ignition switch, no start |
doobie123 |
Aug 5 2022, 04:59 PM
Member Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi all,
just received a new ignition switch from auto atlanta, those guys are great! installed it but still no start. the car will start by jumping the battery to the solenoid with the key in the run position but still wont start with just the key. i should say that i have not put the rest of the steering wheel/ directional switch back together in case it did not work. could this effect it? also it looks like someone before me took the large yellow and yellow/red stripe wire under the passenger seat and hooked them together to bypass the seat belt switch. in addition that relay under the seat and the wires going to it are in bad shape and the mount for the relay has rusted. i'm looking for any suggestions that i could try so please, any help would be great. thanks |
nditiz1 |
Aug 5 2022, 05:20 PM
Senior Member Group: Members Posts: 1,180 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
The bypass is fine. Steering wheel off is fine.
Check continuity from the wire on the starter to your wire on you ignition switch. You can also test power goes to it with a volt meter and an extra person. Definitely install a Ford relay. It costs maybe $50 to do the whole thing. Relay, wires, connectors and that's it. |
Lo-Fi Version | Time is now: 4th May 2024 - 10:02 PM |
