ignition switch, no start |
doobie123 |
Aug 5 2022, 04:59 PM
Member Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi all,
just received a new ignition switch from auto atlanta, those guys are great! installed it but still no start. the car will start by jumping the battery to the solenoid with the key in the run position but still wont start with just the key. i should say that i have not put the rest of the steering wheel/ directional switch back together in case it did not work. could this effect it? also it looks like someone before me took the large yellow and yellow/red stripe wire under the passenger seat and hooked them together to bypass the seat belt switch. in addition that relay under the seat and the wires going to it are in bad shape and the mount for the relay has rusted. i'm looking for any suggestions that i could try so please, any help would be great. thanks |
porschetub |
Aug 5 2022, 07:28 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
hi all, just received a new ignition switch from auto atlanta, those guys are great! installed it but still no start. the car will start by jumping the battery to the solenoid with the key in the run position but still wont start with just the key. i should say that i have not put the rest of the steering wheel/ directional switch back together in case it did not work. could this effect it? also it looks like someone before me took the large yellow and yellow/red stripe wire under the passenger seat and hooked them together to bypass the seat belt switch. in addition that relay under the seat and the wires going to it are in bad shape and the mount for the relay has rusted. i'm looking for any suggestions that i could try so please, any help would be great. thanks So your ignition switch sounds fine,just make sure the rear lower plug is fully on to the column terminals ,mine wasn't and I lost most functions . Questions are ; Are all your battery red terminals nice and new in good connection, is the earth cable from battery to body good, whats the wiring on the starter like, battery good ? ,should be atleast 12.7V sitting, is the connection for seatbelt bypass a good one, did it run previously by bumping the starter, have you checked all body to ground connections by relayboard , others on here will ask further. All these things in good condition should solve your issues if sorted go on to Markhenrys guide to fit Ford solenoid as it works a treat and cheap ...did mine for pocket change. . |
Lo-Fi Version | Time is now: 4th May 2024 - 07:57 PM |
