ignition switch, no start |
doobie123 |
Aug 5 2022, 04:59 PM
Member Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi all,
just received a new ignition switch from auto atlanta, those guys are great! installed it but still no start. the car will start by jumping the battery to the solenoid with the key in the run position but still wont start with just the key. i should say that i have not put the rest of the steering wheel/ directional switch back together in case it did not work. could this effect it? also it looks like someone before me took the large yellow and yellow/red stripe wire under the passenger seat and hooked them together to bypass the seat belt switch. in addition that relay under the seat and the wires going to it are in bad shape and the mount for the relay has rusted. i'm looking for any suggestions that i could try so please, any help would be great. thanks |
dr914@autoatlanta.com |
Aug 6 2022, 01:27 PM
914 Guru Group: Members Posts: 7,833 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
bosch makes their wr1 hot start relay to install if you have voltage drop to the starter. If the trans ground strap is making good connection and the battery is charged and the yellow wire to the solenoid if firmly connected and lights a test light when the key is moved to the start connection, you need the bosch relay kit OR a new starter. We have begun to sell the heavier duty sr68 x in place of the old sr17x
Lo-Fi Version | Time is now: 4th May 2024 - 08:18 PM |
