ignition switch, no start |
doobie123 |
Aug 5 2022, 04:59 PM
Member Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi all,
just received a new ignition switch from auto atlanta, those guys are great! installed it but still no start. the car will start by jumping the battery to the solenoid with the key in the run position but still wont start with just the key. i should say that i have not put the rest of the steering wheel/ directional switch back together in case it did not work. could this effect it? also it looks like someone before me took the large yellow and yellow/red stripe wire under the passenger seat and hooked them together to bypass the seat belt switch. in addition that relay under the seat and the wires going to it are in bad shape and the mount for the relay has rusted. i'm looking for any suggestions that i could try so please, any help would be great. thanks |
nditiz1 |
Aug 6 2022, 03:05 PM
Senior Member Group: Members Posts: 1,180 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
The grey red making it work is just a coincidence. If you leave it in the same place as your pic the key will most likely work.
As for the red wire it has continuity to the battery because it is connected to the battery via the starter, both on the same post. Definitely check the yellow connector is firm as well as the bypass under the pass seat. If you have a helper you can test power to the yellow wire when the ignition switch is momentarily moved to the start position. If your helper holds it there and you have leads on the yellow wire while disconnected you should get 12v. |
Lo-Fi Version | Time is now: 4th May 2024 - 10:44 PM |
