ignition switch, no start |
doobie123 |
Aug 5 2022, 04:59 PM
Member Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi all,
just received a new ignition switch from auto atlanta, those guys are great! installed it but still no start. the car will start by jumping the battery to the solenoid with the key in the run position but still wont start with just the key. i should say that i have not put the rest of the steering wheel/ directional switch back together in case it did not work. could this effect it? also it looks like someone before me took the large yellow and yellow/red stripe wire under the passenger seat and hooked them together to bypass the seat belt switch. in addition that relay under the seat and the wires going to it are in bad shape and the mount for the relay has rusted. i'm looking for any suggestions that i could try so please, any help would be great. thanks |
Superhawk996 |
Aug 7 2022, 05:22 PM
914 Guru Group: Members Posts: 5,778 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Something is mis-wired in your car.
I suspect that someone may have mis-pinned the connector that goes from the relay board to the starter / trans reverse lights. When you turn the key to start position, you should be getting 12+ at the yellow wire. If that is not happening when you turn the key to start - something is mis-wired assuming that you have continuity in the yellow wire as you state. Verify that both connectors (top coming in from cabin) and the right bottom (going out to engine / starter) are pinned correctly. Attached image(s) |
Lo-Fi Version | Time is now: 4th May 2024 - 08:49 PM |
