ignition switch, no start |
doobie123 |
Aug 5 2022, 04:59 PM
Member Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi all,
just received a new ignition switch from auto atlanta, those guys are great! installed it but still no start. the car will start by jumping the battery to the solenoid with the key in the run position but still wont start with just the key. i should say that i have not put the rest of the steering wheel/ directional switch back together in case it did not work. could this effect it? also it looks like someone before me took the large yellow and yellow/red stripe wire under the passenger seat and hooked them together to bypass the seat belt switch. in addition that relay under the seat and the wires going to it are in bad shape and the mount for the relay has rusted. i'm looking for any suggestions that i could try so please, any help would be great. thanks |
doobie123 |
Aug 19 2022, 05:46 PM
ok so heres further the switch was replaced to see if it fixed the problem. the key part was rekeyed at AA.
the plug into the ignition switch looks fine no cracks etc. there are 2 reds,1 yellow, 1 grey, 1grey brown or red stripe, 1 black. one red is constant hot, when the key it turned to start position the other red gets hot, no other ones get hot. could it be the plug is wired wrong? i'll check for splices in the wires to the plug. |
Lo-Fi Version | Time is now: 5th May 2024 - 02:01 AM |
