> ignition switch, no start
doobie123
post Aug 5 2022, 04:59 PM
Post #21
hi all,
just received a new ignition switch from auto atlanta, those guys are great!
installed it but still no start. the car will start by jumping the battery to the solenoid with the key in the run position but still wont start with just the key. i should say that i have not put the rest of the steering wheel/ directional switch back together in case it did not work.
could this effect it?
also it looks like someone before me took the large yellow and yellow/red stripe wire under the passenger seat and hooked them together to bypass the seat belt switch. in addition that relay under the seat and the wires going to it are in bad shape and the mount for the relay has rusted.
i'm looking for any suggestions that i could try so please, any help would be great.
thanks
doobie123   ignition switch   Aug 5 2022, 04:59 PM
nditiz1   The bypass is fine. Steering wheel off is fine. ...   Aug 5 2022, 05:20 PM
doobie123   The bypass is fine. Steering wheel off is fine. ...   Aug 5 2022, 05:31 PM
doobie123   something i didn't say was that there are 4 wi...   Aug 5 2022, 05:34 PM
porschetub   hi all, just received a new ignition switch from ...   Aug 5 2022, 07:28 PM
nditiz1   Any ford relay will work, 1970 ford galaxy, usuall...   Aug 5 2022, 07:33 PM
doobie123   ok, here is an update on the ignition. what i f...   Aug 6 2022, 01:11 PM
nditiz1   I'm not seeing your grey wires with the plug. ...   Aug 6 2022, 01:22 PM
dr914@autoatlanta.com   bosch makes their wr1 hot start relay to install i...   Aug 6 2022, 01:27 PM
doobie123   yes the 2 wires with the bullet connectors are wha...   Aug 6 2022, 01:58 PM
nditiz1   The grey red making it work is just a coincidence....   Aug 6 2022, 03:05 PM
doobie123   ok, thanks i'll give it a try and keep ya post...   Aug 6 2022, 04:06 PM
doobie123   just another question. i thought there was a wire ...   Aug 6 2022, 04:17 PM
nditiz1   That wire is the one that goes under your seat. I...   Aug 6 2022, 08:04 PM
doobie123   ok great, thanks   Aug 7 2022, 12:46 PM
doobie123   ok guys here is a bit of an up date. i cleaned the...   Aug 7 2022, 05:03 PM
Superhawk996   should i just run a new wire from the solenoid to...   Aug 7 2022, 05:24 PM
Superhawk996   Something is mis-wired in your car. I suspect t...   Aug 7 2022, 05:22 PM
doobie123   ok hope all you guys are still out there and are s...   Aug 18 2022, 06:48 PM
emerygt350   I would start with just installing the hot start k...   Aug 18 2022, 07:07 PM
doobie123   thanks emerygt. i gotsa ta know. should i have co...   Aug 18 2022, 07:44 PM
nditiz1   I would not add anything new until you resolve the...   Aug 18 2022, 07:52 PM
emerygt350   Since you have the hot starter kit, put it in. Se...   Aug 19 2022, 12:11 PM
doobie123   ok so i installed the hot start kit and...nothing ...   Aug 19 2022, 01:56 PM
nditiz1   Your switch could be bad. Over time this is what ...   Aug 19 2022, 02:32 PM
emerygt350   I believe he put a new switch in already. I would...   Aug 19 2022, 03:55 PM
doobie123   yes, the switch is new both the plastic plug and t...   Aug 19 2022, 04:13 PM
nditiz1   Sorry missed that about the new switch. Ok so now...   Aug 19 2022, 04:41 PM
doobie123   ok so heres further the switch was replaced to see...   Aug 19 2022, 05:46 PM
- Lo-Fi Version Time is now: 6th October 2026 - 09:22 AM
