WTB 50-55mm wheel studs |
yeahmag |
Aug 10 2022, 12:03 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I have 66mm studs on the car, but have too much stick out (15mm). Anybody sitting on 10 (just doing the rear) studs in the 50-55mm range?
(IMG:style_emoticons/default/beerchug.gif) |
914Sixer |
Aug 11 2022, 07:50 AM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check around. Studs are M14 x 1.5. Should be some universal fits out there. Check SwayAway.com
Montreal914 |
Aug 11 2022, 09:01 AM
Senior Member Group: Members Posts: 1,541 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Curious; (IMG:style_emoticons/default/idea.gif)
You will need to remove the hubs to press these out? Can this be done without damaging the bearing? |
Literati914 |
Aug 11 2022, 09:34 AM
Senior Member Group: Members Posts: 1,437 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Aaron, I think I may have some in a set of 911 front hubs, that I wanted to replace with longer, I'll double check the length. Is your issue 'visual' or something else (hard to change wheels or something else?)?
Olympic 914 |
Aug 12 2022, 06:18 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Curious; (IMG:style_emoticons/default/idea.gif) You will need to remove the hubs to press these out? Can this be done without damaging the bearing? Removed the rear studs using a HF ball joint tool. Didn't have to remove the hub. |
bdstone914 |
Aug 12 2022, 07:00 AM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Curious; (IMG:style_emoticons/default/idea.gif) You will need to remove the hubs to press these out? Can this be done without damaging the bearing? Removed the rear studs using a HF ball joint tool. Didn't have to remove the hub. I know the shorter studs can be removed with the hub installed but there may be a clearance to remove the longer studs as they will hit the trailing arm. |
yeahmag |
Aug 16 2022, 02:37 PM
Bump! Still hoping to find some shorter (used) studs. 45mm fronts are too short FWIW.
gms |
Aug 17 2022, 08:56 AM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
here is the tool i made to remove studs from the rear hubs
brant |
Aug 17 2022, 02:54 PM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Last fall I was looking for 50/55 studs
looked everywhere... but ended up buying brand new from a race shop due to lack of availability.... just looked through my receipts but couldn't find the seller I used. its a not common size it turns out. brant |
yeahmag |
Aug 17 2022, 06:03 PM
acar24 |
Sep 4 2022, 07:03 PM
Newbie Group: Members Posts: 2 Joined: 3-April 07 From: Ne Member No.: 7,641 Region Association: None |
I have 66mm studs on the car, but have too much stick out (15mm). Anybody sitting on 10 (just doing the rear) studs in the 50-55mm range? (IMG:style_emoticons/default/beerchug.gif) I have a set of 10 new studs 52mm . 100 shipped Larry |
Lo-Fi Version | Time is now: 28th April 2024 - 06:01 AM |
