WTB 50-55mm wheel studs |
yeahmag |
Aug 10 2022, 12:03 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I have 66mm studs on the car, but have too much stick out (15mm). Anybody sitting on 10 (just doing the rear) studs in the 50-55mm range?
(IMG:style_emoticons/default/beerchug.gif) |
Montreal914 |
Aug 11 2022, 09:01 AM
Senior Member Group: Members Posts: 1,549 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Curious; (IMG:style_emoticons/default/idea.gif)
You will need to remove the hubs to press these out? Can this be done without damaging the bearing? |
Olympic 914 |
Aug 12 2022, 06:18 AM
Group: Members Posts: 1,663 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Curious; (IMG:style_emoticons/default/idea.gif) You will need to remove the hubs to press these out? Can this be done without damaging the bearing? Removed the rear studs using a HF ball joint tool. Didn't have to remove the hub. |
bdstone914 |
Aug 12 2022, 07:00 AM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Curious; (IMG:style_emoticons/default/idea.gif) You will need to remove the hubs to press these out? Can this be done without damaging the bearing? Removed the rear studs using a HF ball joint tool. Didn't have to remove the hub. I know the shorter studs can be removed with the hub installed but there may be a clearance to remove the longer studs as they will hit the trailing arm. |
Lo-Fi Version | Time is now: 11th May 2024 - 09:07 PM |
