914/4 2,0 ltr Megaquirt, umbau auf Megasquirt |
Slotblack |
Aug 11 2022, 02:27 PM
Newbie Group: Members Posts: 1 Joined: 11-August 22 From: Germany Member No.: 26,763 Region Association: Germany |
Hello and sorry for my spelling! I do everything in Google translator. Is there maybe someone who has info on a GB engine with original intake manifolds with modern injectors? Are there modern injectors that fit directly? Or are there adapters? I want to equip my engine with Megaquirt. Someone is very happy to answer me in German, otherwise I'll translate it in the translator. Thank you in advance and sorry that I don't speak English.
DRPHIL914 |
Aug 11 2022, 02:55 PM
Guten Tag! Standard Injection Corp. makes new injectors, FJ67 . PartsGeek.com listed as part number 17030-05211989
also available on www.summitracing.com , $73.99USD each Also there in Nissan injector that works but i dont know the part number for that. |
JamesM |
Aug 11 2022, 06:24 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
With megasquirt you will want high impedance injectors, which none of the stock ones are.
These are what I use with all my Megasquirt builds, they fit the stock intake runners and fuel rails and do not require resistor packs when used with Megasquirt. https://www.fiveomotorsport.com/a280-a380-h...-fuel-injector/ They are designed for higher fuel pressure though so you will need to change your fuel pressure regulator as well. This one from the dub shop can be installed in the stock location, you will just need to get the proper 5/16 bulkhead fitting. https://thedubshop.com/universal-fuel-press...ackage-builder/ |
Lo-Fi Version | Time is now: 18th May 2024 - 03:37 PM |
