914-6 Oil Cooler Differences |
sixnotfour |
Apr 10 2024, 08:13 PM
914 Wizard Group: Members Posts: 10,418 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
different manufacture.. different last 2 digtis
mb911 |
Apr 11 2024, 08:51 AM
914 Guru Group: Members Posts: 6,818 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
So here is the problem IMHO with OEM 914-6 coolers. It requires you to either adapt from 30mm to whatever line your using or use OEM lines which on a conversion would be silly as the adapter is $50 to got to AN or factory lines which comes in a set of 3 that you only typically use the 2 tank to cooler lines and don’t use the 3rd line that connects to the scavenge line which is very difficult to find and does you no good if you doing a front cooler.
Basically my suggestion on a conversion is to convert a good known cooler, use AN lines much cheaper and fit better for most applications |
pencap914 |
Apr 11 2024, 09:52 AM
Member Group: Members Posts: 75 Joined: 16-April 06 Member No.: 5,872 Region Association: Northern California |
So here is the problem IMHO with OEM 914-6 coolers. It requires you to either adapt from 30mm to whatever line your using or use OEM lines which on a conversion would be silly as the adapter is $50 to got to AN or factory lines which comes in a set of 3 that you only typically use the 2 tank to cooler lines and don’t use the 3rd line that connects to the scavenge line which is very difficult to find and does you no good if you doing a front cooler. Basically my suggestion on a conversion is to convert a good known cooler, use AN lines much cheaper and fit better for most applications For that exact reason I'm sending my oil cooler off today to Pacific Oil Cooler Service INC in La Verne, CA for a cleaning/pressure test then send it off to you for the modification to add the AN fitting. I'll spend $250 for cleaning/testing, then another $150 for the modification. Assuming $50 or so in shipping, still will cost less than half of a new $1000 914-6 OEM style cooler with a $50 AN adapter. After researching here in the forums, it sounds like Pacific Oil Cooler Service is the go-to shop for testing/cleaning of these coolers. I talked to Wayne there yesterday, sounds like he services 911 coolers frequently. https://www.oilcoolers.com/ |
mb911 |
Apr 11 2024, 10:11 AM
So here is the problem IMHO with OEM 914-6 coolers. It requires you to either adapt from 30mm to whatever line your using or use OEM lines which on a conversion would be silly as the adapter is $50 to got to AN or factory lines which comes in a set of 3 that you only typically use the 2 tank to cooler lines and don’t use the 3rd line that connects to the scavenge line which is very difficult to find and does you no good if you doing a front cooler. Basically my suggestion on a conversion is to convert a good known cooler, use AN lines much cheaper and fit better for most applications For that exact reason I'm sending my oil cooler off today to Pacific Oil Cooler Service INC in La Verne, CA for a cleaning/pressure test then send it off to you for the modification to add the AN fitting. I'll spend $250 for cleaning/testing, then another $150 for the modification. Assuming $50 or so in shipping, still will cost less than half of a new $1000 914-6 OEM style cooler with a $50 AN adapter. After researching here in the forums, it sounds like Pacific Oil Cooler Service is the go-to shop for testing/cleaning of these coolers. I talked to Wayne there yesterday, sounds like he services 911 coolers frequently. https://www.oilcoolers.com/ Be careful I sent them an almost new one from @mepstein and they told me it was no good. I should have had them send it back but ended up buying a new 911 one from Porsche and modifying for my car. |
pencap914 |
Apr 11 2024, 10:34 AM
QUOTE Be careful I sent them an almost new one from @mepstein and they told me it was no good. I should have had them send it back but ended up buying a new 911 one from Porsche and modifying for my car. Good to know. Is there another reputable oil cooler cleaning/test shop? I thought there was one in central California but google isnt coming up with any hits... |
Apr 11 2024, 12:29 PM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
mb911 |
Apr 11 2024, 12:57 PM
QUOTE Be careful I sent them an almost new one from @mepstein and they told me it was no good. I should have had them send it back but ended up buying a new 911 one from Porsche and modifying for my car. Good to know. Is there another reputable oil cooler cleaning/test shop? I thought there was one in central California but google isnt coming up with any hits... Not sure. I am thinking it was a fluke |
IronHillRestorations |
Apr 15 2024, 01:29 PM
I. I. R. C. Group: Members Posts: 6,715 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Just to be clear; the "911 style" oil cooler with the straight push-on fitting will not clear the suspension in a 914? (Picture below) If that's the case, is it possible to have a skilled welder (*cough* @MB911 ) modify the stock 911 oil cooler to fit a 914? Or should I start shopping for a replacement cooler? The CFS #8260 looks like its made for a 914/6 conversion: https://y7y6i2a9.rocketcdn.me/wp-content/up...-8260-Flyer.pdf I have modified the later style 911 oil cooler with an aluminum 90* fitting that is-12AN and 3/4 NPT. You cut off the tube flush with the end of the cooler and tap it with a 3/4 NPT tap. The tricky part is you want to have it thread in all the way and point forward and about 4* down. Then you are good to go with-12 hoses and fittings. |
ClayPerrine |
Apr 15 2024, 02:19 PM
Life's been good to me so far..... Group: Admin Posts: 15,430 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Why not just shorten the tube and put a straight fitting on it, then use a 90 degree bend to connect it to the hose?
Apr 15 2024, 02:38 PM
Resident German Group: Admin Posts: 41,610 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Why not just shorten the tube and put a straight fitting on it, then use a 90 degree bend to connect it to the hose? In short, a tight 90 degree angle restricts flow. (IMG:style_emoticons/default/popcorn[1].gif) The curved design of the stock cooler is superior: (IMG:http://www.914world.com/bbs2/uploads/post-994-1393507286.jpg) |
troth |
Apr 15 2024, 04:44 PM
Member Group: Members Posts: 151 Joined: 17-August 16 From: CT/WA Member No.: 20,305 Region Association: None |
Don't want derail the thread on the original issue of the 01 vs 03 cooler (which I have also unsuccessfully tried to find an answer on in the past). But has anybody tried the csf cooler? I keep seeing them advertised and with what they're claiming it would be my first choice, but would like to hear some real world feedback before purchasing.
ClayPerrine |
Apr 16 2024, 08:18 AM
Why not just shorten the tube and put a straight fitting on it, then use a 90 degree bend to connect it to the hose? In short, a tight 90 degree angle restricts flow. (IMG:style_emoticons/default/popcorn[1].gif) The curved design of the stock cooler is superior: (IMG:http://www.914world.com/bbs2/uploads/post-994-1393507286.jpg) I may not have explained my idea clearly. Usw a short tube and a fitting like the one below in the appropriate size |
mb911 |
Apr 16 2024, 02:38 PM
technicalninja |
Apr 16 2024, 02:51 PM
Senior Member Group: Members Posts: 1,173 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
What is the grey material on the aluminum tube that appears to be bonding the threaded hex section to the tube?
mb911 |
Apr 16 2024, 03:22 PM
targa72e |
Apr 16 2024, 10:18 PM
Member Group: Members Posts: 262 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
930cabman |
Apr 17 2024, 09:29 AM
Advanced Member Group: Members Posts: 3,007 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
If/when doing this again, I would definitely go with the CSF
gereed75 |
Apr 17 2024, 05:39 PM
Senior Member Group: Members Posts: 1,241 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Targa72e. Nice find on that fitting. Made my own with drill and tap Works great but this premade one is trick.
Lo-Fi Version | Time is now: 2nd May 2024 - 03:39 PM |
