Best carbed warm start procedure |
bbrock |
Aug 18 2022, 04:15 PM
Apologies if this is addressed somewhere, but couldn't find anything with google search.
I'm wondering if there is a "proper technique" for warm starting a 914/4 with 40 IDFs. To be clear, I'm only interested in what to do with my right foot when starting after the car sat with a hot engine for 15-30 minutes. I'm hoping to megasquirt the engine over the winter so will happily just live with what is a minor annoyance before spending time or money chasing a fuel boiling issue or similar. Here's some background on my stock 2L with 40IDFs and mild Elgin carb cam. Timing is set at ~32deg BTDC. Fuel pump is relocated to the front 75-76 location. I run a fuel return line, and I have phenolic spacers between the intakes and heads. I spent a lot of "quality time" with my carbs and a wide band earlier this summer and they are dialed in and running SWEET. I was running the stock dizzy with injector contacts blocked off and the car ran well, fired instantly when hot or cold, and idled steady. My old dizzy started acting erratic so I swapped it for a new Pertronix SVDA with Ignitor III replacing the points. That is when the warm start issue showed up. Car fires nearly instantaneous on cold starts, but when the engine is fully warmed up and then left to sit 15-30 minutes, I have to crank too long to fire it up again. Seems like holding the accelerator for WOT works best to get it to catch but I haven't played with different combos too much. Once it catches, it coughs back to life and runs a bit rough for about a minute while it spits out the extra gas. I suppose the E85 might still be boiling in the carb bowls despite the return line and phenolic spacers. If so, I'll just live with it for now, but wonder what folks think is the best throttle position for starting a warm set of carbs. Also open to suggestions for holding my tongue or mouth a certain way if that will help. And for sure a magic combination of swear words would be welcome as I"m a huge fan of those. (IMG:style_emoticons/default/happy11.gif) |
Superhawk996 |
Aug 19 2022, 09:00 PM
914 Guru Group: Members Posts: 5,853 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I suppose the E85 might still … Hey buddy! I’m going to troll for a minute. Your supposed to be running the car on GASOLINE. E85 is 85% Ethanol So I’m going to assume you mean your running E15 which is 15% ethanol 85% gasoline Even so - I’d be trying to avoid alcoholism and would try to find a gas station that uses no more than 10% ethanol (E10). But in all seriousness if it started with the Pertronix install . . . I’d bet that is your problem. At the risk of offending those that love them. I think Pertronix is rubbish based on their previous products lack of reverse polarity protection and lack of key on thermal protection. I know those are supposed to be solved with Perteonix III but god only knows what the new bugs are and or what new thermal issues it may have leading to extended cranking. You’ll sort it out ! @bbrock |
bbrock |
Aug 19 2022, 11:40 PM
I suppose the E85 might still … Hey buddy! I’m going to troll for a minute. Your supposed to be running the car on GASOLINE. E85 is 85% Ethanol So I’m going to assume you mean your running E15 which is 15% ethanol 85% gasoline Even so - I’d be trying to avoid alcoholism and would try to find a gas station that uses no more than 10% ethanol (E10). But in all seriousness if it started with the Pertronix install . . . I’d bet that is your problem. At the risk of offending those that love them. I think Pertronix is rubbish based on their previous products lack of reverse polarity protection and lack of key on thermal protection. I know those are supposed to be solved with Perteonix III but god only knows what the new bugs are and or what new thermal issues it may have leading to extended cranking. You’ll sort it out ! @bbrock Yeah, you got me. E10 is what I'm using. I didn't think E85 sounded right. They actually don't use that much ethanol around here. Pure gasoline is pretty easy to find but $$$. Agree about Pertronix. The only thing worse is a set of points. Gawd I hate those things. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/happy11.gif) I'm actually leaning toward timing. Maybe just a tad too much advance when trying to start warm. Don't assume I'll get it sorted though. My motivation is very low. As long as it takes $0 and less than an hour of time, I'm willing to fiddle. Beyond that is just not worth it. I did fiddle around with different throttle positions when running errands tonight. Foot to the floor is definitely the best. |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:53 PM |
