Front Bumper Alignment, Need suggestions/how to for improving front bumper alignment |
mjsdt914 |
Aug 19 2022, 08:08 AM
Newbie Group: Members Posts: 26 Joined: 10-August 21 From: Montana Member No.: 25,791 Region Association: Rocky Mountains |
Any suggestions for improving front bumper alignment greatly appreciated. The mounting bolts are fully seated with the appropriate washers/lock washers. Right side is better than the left side; neither are very good. My trusted local body shop declined to try as this is the first 914 they've seen...LOL
mlindner |
Aug 19 2022, 08:32 AM
Senior Member Group: Members Posts: 1,512 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
mjsdt914 |
Aug 19 2022, 09:00 AM
Does anyone know where to find bumper spacers of different sizes to use on each mounting bolt?
Mikey914 |
Aug 19 2022, 09:04 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The bumper spacers need to be installed. Most folks don't even know they are there. You can shim with a stainless washer if you need any adjustment, but shouldn't really need that. You can make your own is you want, but this is what I'm talking about.
https://914rubber.com/bumper-top-spacers |
Aug 19 2022, 10:17 AM
The bumper could be tweaked, the front end could be off or both. You never know what’s happened on these 50 year old cars. Sometimes you just have to go to the hardware store and buy enough washers to make it work.
If it was me, I’d remove the bumper, put it on a flat floor and take a good look at both the bumper and the front end. It might reveal a twist that you have to compensate for. A laser level pointed at the front end can also be very telling. |
T.Rick6 |
Aug 19 2022, 10:55 AM
Member Group: Members Posts: 51 Joined: 1-October 19 From: Douglasville, Ga Member No.: 23,512 Region Association: South East States |
Your car is a '74 with early bumbers, I believe there's a little sheetmetal that has to be trimmed; I don't recall where exactly, other members have done the mod, braintrust please chime in if i'm incorrect.
Todd |
dr914@autoatlanta.com |
Aug 19 2022, 11:05 AM
914 Guru Group: Members Posts: 7,817 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the replacement spacers are too hard and do not squeeze down like the originals. All of these bumpers had to be jimmied around with to get a good fit, the harder dog bones can be shaved when you install the bumper pull it up as much as you can and tighten the top bolt first
JoeD |
Aug 19 2022, 11:29 AM
Member Group: Members Posts: 156 Joined: 19-July 15 From: Atlanta, GA Member No.: 18,973 Region Association: South East States |
The bumper spacers need to be installed. Most folks don't even know they are there. You can shim with a stainless washer if you need any adjustment, but shouldn't really need that. You can make your own is you want, but this is what I'm talking about. https://914rubber.com/bumper-top-spacers Timely, as I was ready to install my front and rear bumpers this weekend and I do not have those spacers, though I have all new hardware for everything else. Mark, your website lists them as a "set of 10", but then defaults to a qty of 10... so assuming I need 10 of these, but when I try to add 10 to the cart it won't let me. Any idea when they'll be back in stock, or do I just go to ACE and find some rubber spacers that fit? |
mgphoto |
Aug 19 2022, 11:54 AM
"If there is a mistake it will find me" Group: Members Posts: 1,336 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Any suggestions for improving front bumper alignment greatly appreciated. The mounting bolts are fully seated with the appropriate washers/lock washers. Right side is better than the left side; neither are very good. My trusted local body shop declined to try as this is the first 914 they've seen...LOL The bumper looks tweeted, brackets could be bent. Also did you install the rubber spacers between the bumper and the rubber bumper pad? |
mjsdt914 |
Aug 19 2022, 12:41 PM
Any suggestions for improving front bumper alignment greatly appreciated. The mounting bolts are fully seated with the appropriate washers/lock washers. Right side is better than the left side; neither are very good. My trusted local body shop declined to try as this is the first 914 they've seen...LOL The bumper looks tweeted, brackets could be bent. Also did you install the rubber spacers between the bumper and the rubber bumper pad? This is the right side. I appreciate all the suggestions! Attached thumbnail(s) |
Aug 19 2022, 01:00 PM
rgalla9146 |
Aug 19 2022, 05:36 PM
I suspect there is some poor damage repair.
I'd do as Mark suggested, remove the bumper and evaluate. Clever adjustment can work wonders. Attached thumbnail(s) |
Geezer914 |
Aug 20 2022, 05:54 AM
Geezer914 Group: Members Posts: 1,384 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
cut the dog bones to half the width.
Lo-Fi Version | Time is now: 25th April 2024 - 08:22 PM |
