rush to red rocks classic, How not to prepare for an event |
targa72e |
Aug 22 2022, 11:48 PM
Member Group: Members Posts: 262 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
So, jump forward. My 914 -6 conversion now has its 4th motor and can move under its own power. Planning on driving from Denver to Salt lake for RRC.
About 5 years ago I decided to jump into the 914 world. I have several 911 engines needing projects and roller 911's have become really expensive ( and I have two 911 rollers that are already planed projects) so I bought a 914 for a -6 conversion. Not knowing much at the time I got lucky with pretty rust free 73. It has kind of become my engine mule. First engine was a 2.4 MFI motor with S pistons and Ecams. Used it to decide if I like 914's, I do. Mule as it looks now. Ended up selling that motor to another 914 world member in Florida. My friend (who will be joining me at Red Rocks, also shares the same name) also had engines that needed to be built. So with the engine bay empty we built a 2.7 RS+ engine with RS pistons and Mod S cams and weber carbs. This was a big step up. Dyno below of 2.4 E with S cams vs 2.7 RS+. We are working to get his 76 911 travel capable but if he is too soft for no AC he will bring his 01 turbo (you can give him crap). His 2.7 made my 914 much more fun. I had a 2.7 engine in planning for "my 914" that this helped solidify the specs. Since I jumped into the 914 world I started looking for "my 914" project to build how I wanted based on my experience so far. This resulted in having 4 914's at one point. One of the cars I purchased sent me down a side road. It was originally a sad neglected car with great potential. I purchased it thinking it would make a great start for "my 914-6" but was ultimately too nice for me to modify so I spent a year and a half bringing it back to good health. It was purchased by another 914 member and should be at RRC as well. Story hear. http://www.914world.com/bbs2/index.php?sho...mp;hl=white+car So after my friends engine vacated my cars engine bay I decided to build what I called my "junk yard dog" motor. This was built from parts I had that had no home. While not in new spec they were not yet worn out. They consisted of a 2.4 case that I used my new mill to add case savers and deck ( it was quite warped in this area). It was built to similar spec to the first engine, 2.4 with JE pistons 9.5 to 1 and E cams. It had T heads ported to S specs and ran Zenith TIN carbs instead of MFI from first engine. Made great power with the larger ports and a little more compression compared to stock port size MFI engine I originally built. So ended up purchasing a bunch of 914 and 911 parts early this winter. This included a mostly ready to build motor plus a spare 2.7. About the same time I saw a post from some one with a 912 that wanted a complete 911 motor. Why not sell the "junk yard dog", I had a good 6 months until RRC why not make my 914 immobile again (IMG:style_emoticons/default/smile.gif) I would have plenty of time to build another engine. Too be continued John See you at RRC one way or another. |
targa72e |
Sep 11 2022, 11:27 AM
My friend (also John) who is also going to Red Rocks is trying to get his 76 911 ready and one of the issues is a broken exhaust stud. I take some time to make a tool so he can drill it out on the car.
This was a quick build and not pretty but worked perfect to drill out broken stud. John lives about 45min from me so seamed like good opportunity to put on some miles. Decided to double check the axle bolts for tightness as this has bit me more than once where after initial torque, some gasket compression and bolts are loose. Sure enough several bolts on one axle were loose. Car ran good on trip but idle and transition are still an issue. Started reading more carb tuning post and decide I might need larger idle jets. I did not have time to order so I ordered a micro drill set off Amazon to enlarge the ones I have, figure these should also work good to clean the tiny hole in idle jets as a starting point. Week end of August 27th, Only two more weekend until I plan to leave. When I start checking idle jets and prepare to drilling larger I discover some have already been drilled larger and some are stock. I drill out the stock ones to match those already enlarged. I take the car out for a short drive, runs much better with all the same size jets and lean transition is gone. However car starts making loud drive train noise in rear. My first thought is I am about to lose a axle. Head home and jack up car. When I rotate wheel I can see the speedometer cable is jumping around. Rotate wheel some more and speedo drive is trying to rotate as well then some bad noise and everything is good. Speedo cable was dying, now broken. This has been a recurring problem (i am on my 4th). I decide I am not going to fix and will use phone app for GPS speedometer for trip. Now I can take the car back out for a highway drive. Car runs good but cruise AF ratios are in the 11's, I little rich for a long trip. Idle AF is high 13 low 14. Decide to put 6 stock idle jets back in. This means starting over on carb tuning. Did I mention I hate carbs. Back to square one. With new jets transition lean miss is back, highway cruise AF rations much better in the 13 range. Will leave as is for now. Since I will leave my house and drive a 1/2 mile to interstate and then 8 hours of cruise the good cruise AF ratio seams like a good choice, once I am in Salt Lake I will put the larger drilled jets back in and switch out again for drive home. Start hitting smaller projects. When I got the car the ignition key did not match the rest of the locks. Might be nice to be able to lock car so I re-keyed the doors and the trunk. Now I can lock the car. Another weekend done... |
Lo-Fi Version | Time is now: 19th May 2024 - 11:42 AM |
