Pedal Board Adjustment, What Did I Do? |
NARP74 |
Aug 25 2022, 10:07 AM
Senior Member Group: Members Posts: 1,063 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I was fixing a pedal board issue, no hardware, wrong hardware, poor alignment, etc. Once I got all that worked out, I was going for a drive and the clutch was barely engaging. Made for a tough drive. 1st and Rev were grinding and the others were not much better.
I did find a list of things to check for issues like this and I am going through those. I also saw the Dr Evil drawing for clutch engagement. Mine seems to engage just off the pedal stop now. Is there a real spec for clutch adjustment or is it just by feel? How could this be related to the pedal board? It was fine before I moved it around. |
BeatNavy |
Aug 25 2022, 10:10 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Just a swag, but maybe in the process of adjusting and fiddling with the board (it can be finnicky, I know) you may have yanked the cable and broken loose one of the spot welds for the clutch tube inside the tunnel.
NARP74 |
Aug 25 2022, 10:27 AM
Just a swag, but maybe in the process of adjusting and fiddling with the board (it can be finnicky, I know) you may have yanked the cable and broken loose one of the spot welds for the clutch tube inside the tunnel. I hope not but it is on my list of things to check. |
Lo-Fi Version | Time is now: 15th May 2024 - 04:59 PM |
