Pedal Board Adjustment, What Did I Do? |
NARP74 |
Aug 25 2022, 10:07 AM
Senior Member Group: Members Posts: 1,063 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I was fixing a pedal board issue, no hardware, wrong hardware, poor alignment, etc. Once I got all that worked out, I was going for a drive and the clutch was barely engaging. Made for a tough drive. 1st and Rev were grinding and the others were not much better.
I did find a list of things to check for issues like this and I am going through those. I also saw the Dr Evil drawing for clutch engagement. Mine seems to engage just off the pedal stop now. Is there a real spec for clutch adjustment or is it just by feel? How could this be related to the pedal board? It was fine before I moved it around. |
NARP74 |
Aug 25 2022, 07:36 PM
I tightened one side of the pedal stop that was loose, the washer was rattling. I leveled it out and tightened it. I guess that could have taken up any travel that it needed. But if that is the case the clutch is not adjusted correctly. The pedal stop might have been at an angle as the one side that was loose slid up to the top of the board. it is almost all the way at the top of the board. Not sure where it is supposed to be.
Lo-Fi Version | Time is now: 15th May 2024 - 05:04 PM |
