Pedal Board Adjustment, What Did I Do? |
NARP74 |
Aug 25 2022, 10:07 AM
Senior Member Group: Members Posts: 1,063 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I was fixing a pedal board issue, no hardware, wrong hardware, poor alignment, etc. Once I got all that worked out, I was going for a drive and the clutch was barely engaging. Made for a tough drive. 1st and Rev were grinding and the others were not much better.
I did find a list of things to check for issues like this and I am going through those. I also saw the Dr Evil drawing for clutch engagement. Mine seems to engage just off the pedal stop now. Is there a real spec for clutch adjustment or is it just by feel? How could this be related to the pedal board? It was fine before I moved it around. |
NARP74 |
Aug 25 2022, 08:54 PM
The plot thickens... I am missing the stop plate washer, the boot and a washer on the roller. I am wondering if moving the pedal board around caused some slack and the cable changed position due to the missing washer making the clutch operation more slack. I was able to move things by hand easily. It was not like this until I pulled on the cable a little. It should not do this so easily...
JamesM |
Aug 25 2022, 09:13 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
The plot thickens... I am missing the stop plate washer, the boot and a washer on the roller. I am wondering if moving the pedal board around caused some slack and the cable changed position due to the missing washer making the clutch operation more slack. I was able to move things by hand easily. It was not like this until I pulled on the cable a little. It should not do this so easily... Yeah, that would for sure make your clutch a little more difficult to operate. |
Lo-Fi Version | Time is now: 15th May 2024 - 03:07 PM |
