Pedal Board Adjustment, What Did I Do? |
NARP74 |
Aug 25 2022, 10:07 AM
Senior Member Group: Members Posts: 1,063 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I was fixing a pedal board issue, no hardware, wrong hardware, poor alignment, etc. Once I got all that worked out, I was going for a drive and the clutch was barely engaging. Made for a tough drive. 1st and Rev were grinding and the others were not much better.
I did find a list of things to check for issues like this and I am going through those. I also saw the Dr Evil drawing for clutch engagement. Mine seems to engage just off the pedal stop now. Is there a real spec for clutch adjustment or is it just by feel? How could this be related to the pedal board? It was fine before I moved it around. |
targa72e |
Aug 25 2022, 10:59 PM
Member Group: Members Posts: 262 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
Your clutch cable is not engaged properly. The cable should be in the slot at the point of the arrow in pic. None of my cars have had that washer listed by others but seems like a good idea. One car I purchased had some wire to hold the cable in place. I will probably add the washer as it seems like a good idea but has not been a problem yet.
Having just adjusted my clutch tonight. Adjust the cable at the tranny end until you get to the point that you can just put it in reverse with out grinding. john |
Lo-Fi Version | Time is now: 15th May 2024 - 06:45 PM |
