Pedal Board Adjustment, What Did I Do? |
NARP74 |
Aug 25 2022, 10:07 AM
Senior Member Group: Members Posts: 1,063 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I was fixing a pedal board issue, no hardware, wrong hardware, poor alignment, etc. Once I got all that worked out, I was going for a drive and the clutch was barely engaging. Made for a tough drive. 1st and Rev were grinding and the others were not much better.
I did find a list of things to check for issues like this and I am going through those. I also saw the Dr Evil drawing for clutch engagement. Mine seems to engage just off the pedal stop now. Is there a real spec for clutch adjustment or is it just by feel? How could this be related to the pedal board? It was fine before I moved it around. |
NARP74 |
Sep 3 2022, 05:03 PM
Got the repair parts, thanks Mikey. Took it all apart, cleaned it up and started the install. The threads at the end of the cable were buggered so I had to chase those the whole way. Got it back together the proper way and am going through the clutch adjustment, test drive, adjust process. Much better now. 10 bucks worth of washers and rubber boots that someone skipped during the re-install.
Everything I touch is a learning process on these cars. |
Lo-Fi Version | Time is now: 14th May 2024 - 11:40 PM |
