Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
DennisV |
Senior Member ![]() ![]() ![]() Group: Members Posts: 670 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California ![]() ![]() |
1970 914-6 were fitted with a Marelli distributor. Whereas 1971-1972 cars had Bosch distributors. The Marelli distributor came in AX and BX versions. Cars built prior to April 1970 would have CDI (Capacitor Discharge Ignition) and a Marelli BX. BX models did not have a condenser, as it wasn’t necessary for cars with CDI . Those without CDI utilized the AX.
Weak points of the Marelli have included difficulty in obtaining parts. It has an aluminum body. Pictured is a refurbished Marelli S112 BX distributor with the cap and retaining clips removed. ![]() |
Lo-Fi Version | Time is now: 14th July 2025 - 08:48 PM |
