Center the steering wheel, How? |
NARP74 |
Sep 1 2022, 09:35 AM
Senior Member Group: Members Posts: 1,062 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
The car had an alignment just before I bought it but the steering wheel is a bit off center. What is the best way to move that back without messing anything else up?
Cairo94507 |
Sep 1 2022, 09:56 AM
Michael Group: Members Posts: 9,750 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
The only other way, depending upon how close it is to being centered is to adjust the tie rod ends to center wheel. Take off 1/4 turn at a time and add 1/4 turn to the other side, depending upon which way the wheel needs to go.
Make the adjustment, take it for a ride and see what you have. The key is to make small adjustments until you get it centered exactly. Just had mine aligned and watched the guy center the wheel perfectly. (IMG:style_emoticons/default/beerchug.gif) |
Superhawk996 |
Sep 1 2022, 02:14 PM
914 Guru Group: Members Posts: 5,807 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Make the adjustment, take it for a ride and see what you have. The key is to make small adjustments until you get it centered exactly. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) Tip: put a paint line on the tie rod before you start adjusting so you: 1) have a reference to gauge how much you’ve turned the tie rod 2) have a known location to return to 3) can gauge that you’ve moved each side the same amount - thereby not disturbing the toe setting. |
Lo-Fi Version | Time is now: 13th May 2024 - 07:21 AM |
