Front Recovery Tow Point, Jman Option |
jdamiano |
Sep 4 2022, 06:16 PM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
My car has dealership installed AC so the front tow point is gone. I got it with a bent drop link I’m sure was the result of a past tow. I’m trying to figure out what my options are and found these tie downs from Jman. Has anyone used these or something similar? If so I would really appreciate a picture of one installed.
Attached image(s) |
Superhawk996 |
Sep 5 2022, 01:07 PM
914 Guru Group: Members Posts: 5,754 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
By turning those around and eliminating the 3rd fastener you are likey going to find that they fold up when you need them.
Two fasteners creates a hinge point where they will bend when loaded. Also front suspension fasteners should be Grade 10.9 not 8.8. Metric grade 8.8 is basically equivalent to SAE grade 5. |
jdamiano |
Sep 5 2022, 01:27 PM
By turning those around and eliminating the 3rd fastener you are likey going to find that they fold up when you need them. Two fasteners creates a hinge point where they will bend when loaded. Also front suspension fasteners should be Grade 10.9 not 8.8. Metric grade 8.8 is basically equivalent to SAE grade 5. If it fold great. Maybe it will create more clearance causing less chance of damage to the valance. I might also gusset it on the sides. Never work on my baja bug since it gets pulled hard sometimes. I had it up to the doors in mud a few months ago and it got snatched hard. Hopefully I never need this and if I do it’s a slow pull onto a flatbed. I’m also going to add a soft shackle to my trunk supply to go from this to any cable the tow guy wants to use. I will take your advice on the bolts though. Thanks. |
Lo-Fi Version | Time is now: 28th April 2024 - 04:11 AM |
