Front Recovery Tow Point, Jman Option |
jdamiano |
Sep 4 2022, 06:16 PM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
My car has dealership installed AC so the front tow point is gone. I got it with a bent drop link I’m sure was the result of a past tow. I’m trying to figure out what my options are and found these tie downs from Jman. Has anyone used these or something similar? If so I would really appreciate a picture of one installed.
Attached image(s) |
914werke |
Sep 18 2022, 07:54 AM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Confused about intended use? Title says "Tow point" are those actually intended to tow with ? I thought they are more focused as a
Recovery point. Agree with previous comments, you really need that front bolt as it's the only that penetrates & is seam welded to the tub, & for fitment you have to remove the covers. |
jdamiano |
Sep 18 2022, 08:24 AM
Confused about intended use? Title says "Tow point" are those actually intended to tow with ? I thought they are more focused as a Recovery point. Agree with previous comments, you really need that front bolt as it's the only that penetrates & is seam welded to the tub & for fitment you have to remove the covers. I’m trying to add a good place to hook a tow cable to in case I need to drag it up my trailer or a tow truck. I haven’t found one 914 specific that doesn’t stick out the front. This one was listed for a 914 but that front bolt no way matches the location on a 914. Also if I install it with the third bolt hole facing forward I can’t reinstall the torsion bar protector. Right now I’m thinking I’m going to keep it pointing the same way but move it below the mount bracket. The loop on this one is closer to the two bolts and shorter than the ones posted earlier in this thread so I think it will be strong enough. If someone has a better solution I’m all ears! |
ChrisFoley |
Sep 18 2022, 08:42 AM
I am Tangerine Racing Group: Members Posts: 7,910 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I’m trying to add a good place to hook a tow cable to in case I need to drag it up my trailer or a tow truck. I haven’t found one 914 specific that doesn’t stick out the front. ... If someone has a better solution I’m all ears! I will be releasing a new product in just a few weeks which should fully address your needs and concerns. |
robkammer |
Sep 26 2022, 04:39 PM
Member Group: Members Posts: 179 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: North East States |
I’m trying to add a good place to hook a tow cable to in case I need to drag it up my trailer or a tow truck. I haven’t found one 914 specific that doesn’t stick out the front. ... If someone has a better solution I’m all ears! I will be releasing a new product in just a few weeks which should fully address your needs and concerns. Hi Chris: Keep me in the loop as I would like to have some tow ability for my BB. The dealer Air screwed the front tow hook. Rob Robkammer16@gmail.com |
Lo-Fi Version | Time is now: 28th April 2024 - 08:38 AM |
