Oil Breather Cover Lid, 901.107.701.3R |
DennisV |
Sep 4 2022, 06:23 PM
Member Group: Members Posts: 471 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
johnhora |
Sep 5 2022, 08:39 AM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
DennisV |
Sep 9 2022, 10:09 AM
rgalla9146 |
Sep 9 2022, 01:49 PM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
914-6 intake manifold with vacuum ports Very interesting! Thanks for the visual aids. Do you know if those ports were threaded? Our engine was missing the carbs. What we have now is a set of Zenith. The intake manifold has openings, but they are are not threaded. Dennis those carbs and manifolds are from a '70-'71 2.2 911T Two year only combination. Not drilled for the vacuum ports....but could be. How serious is your restoration ? Those manifolds will be just fine on your 6 unless you insist on the absolute correct parts. The only difference is the vacuum ports which you will likely never use. |
DennisV |
Sep 9 2022, 04:12 PM
Dennis those carbs and manifolds are from a '70-'71 2.2 911T Two year only combination. Not drilled for the vacuum ports....but could be. Thanks for sharing this. The devil in the details with the sharing between and evolution of these Porsche cars. (IMG:style_emoticons/default/unsure.gif) How serious is your restoration ? Those manifolds will be just fine on your 6 unless you insist on the absolute correct parts. The only difference is the vacuum ports which you will likely never use. Very fair question. It is an original 914-6 in quite good condition, but not numbers matching (i.e. the chassis came without engine or transmission. We have number range appropriate replacements). So for things that are missing or need replacement, I plan to go stock config with Porsche or OES parts. The exception might be if we have to get new pistons and cylinders. Anything that we already have (e.g. carbs) that will work without requiring modification I will continue using till they need replacing. Or my obsessive tendency doesn't allow it to remain. (IMG:style_emoticons/default/screwy.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 10:38 AM |
