Targa Top Issues, Loose |
NARP74 |
Sep 5 2022, 08:52 AM
Senior Member Group: Members Posts: 1,067 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I have noticed some creaking coming from the rear targa top area when I drive. I lifted up on all four corners of the top and the right rear is loose. Even when the top is latched, I can lift it up a bit. That is probably my issue, but what is the fix?
jim_hoyland |
Sep 5 2022, 09:57 AM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I recently went through the same thing,right rear corner creaked. Keith (914Toy) helped to fix mine. With the top off, he used a C-Clamp to bend the hook part of the latch down.It doesn't much bending, 1/4" at most.
Since one of my latches was bad,I replaces both with Bruce Stone rebuilds. They worked perfect.Only problem was getting the targa pad off..... I also replaced the rear targa top seal |
Lo-Fi Version | Time is now: 18th May 2024 - 11:46 PM |
