Targa Top Issues, Loose |
NARP74 |
Sep 5 2022, 08:52 AM
Senior Member Group: Members Posts: 1,068 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I have noticed some creaking coming from the rear targa top area when I drive. I lifted up on all four corners of the top and the right rear is loose. Even when the top is latched, I can lift it up a bit. That is probably my issue, but what is the fix?
bdstone914 |
Sep 5 2022, 07:41 PM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have noticed some creaking coming from the rear targa top area when I drive. I lifted up on all four corners of the top and the right rear is loose. Even when the top is latched, I can lift it up a bit. That is probably my issue, but what is the fix? @NARP74 Make sure you have the correct too. The rubber blocks for the early tops are shorter andcwider. A nickle will fit between the bumps on a late latch and a quarter is the width of the early latch. Compare that to the width of the rubber block tgat fits unto the top of the latch. |
Lo-Fi Version | Time is now: 26th May 2024 - 11:10 PM |
