Transaxle Reverse Light Switch |
bkrantz |
Sep 11 2022, 07:38 PM
914 Guru Group: Members Posts: 7,761 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Can one of you transaxle gurus tell me if removing the reverse light switch will let the lube out? My switch seems to be bad.
Attached thumbnail(s) |
Dr Evil |
Sep 12 2022, 09:03 PM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Yes. It will leak. Leave bad switch in as plug if for no other reason. Check switch to assure IT is bad and not the pin being to worn down. The last pin I made was 29mm, they actually can vary depending on year and mfr of switch.
bkrantz |
Sep 13 2022, 08:22 PM
Yes. It will leak. Leave bad switch in as plug if for no other reason. Check switch to assure IT is bad and not the pin being to worn down. The last pin I made was 29mm, they actually can vary depending on year and mfr of switch. I was able to make it work. The switch checked out, and the pin action was fine, but did not project into the switch enough to close the circuit. The trans rebuilder had used a thick spacer/washer under the switch. I swapped that out and the pin triggers the switch. |
Lo-Fi Version | Time is now: 13th May 2024 - 09:24 PM |
