Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,307 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
so it looks like there's going to be some minor machining required after all.
turns out, the 944 Turbo CVs are 4mm thicker than the 914 CVs which means the 914 axle shaft has to be machined down a bit for them to fit. see pictures below ... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy 1 - 914 shaft on top, 944 shaft below (IMG:http://www.914world.com/bbs2/uploads/post-11-1123372532.jpg) 2 - closeup, for difference, see table below ... (IMG:http://www.914world.com/bbs2/uploads/post-11-1123372553.jpg) 3 - 4 mm needs to be removed from the 914 shaft to accomodate the 944 CV (IMG:http://www.914world.com/bbs2/uploads/post-11-1123372569.jpg) 4 - 914 CV on the left, 944 CV on the right (IMG:http://www.914world.com/bbs2/uploads/post-11-1123372588.jpg) 5 - 914 CV on the left, 944 CV on the right (IMG:http://www.914world.com/bbs2/uploads/post-11-1123372608.jpg) Dimensions: 914 Shaft, dia. = 25mm, length = 514mm 944 Shaft, dia. = 26mm, length = 540mm 914 CV, dia. = 94mm, width = 31mm 944 CV, dia. = 100mm, width = 35mm |
Lo-Fi Version | Time is now: 24th August 2025 - 01:49 PM |
