new 914 with Gearbox Issues |
tonybolony |
Sep 17 2022, 09:11 AM
Newbie Group: Members Posts: 30 Joined: 17-September 22 From: Enland , Wes Yorkshire Member No.: 26,859 Region Association: None |
So new oener here , messing with my 1972 car , i have noticed that i dont seem to have 4/5 gear , i did mess and i ended up loosing Reverse , so am starting to lose the will to live lol, is there a guide on setting up linkages ? i also notice my shifter doent seem to go to the right much also, not sure if thats part of the problem ? but too travel left its got loads and its springs back also ?
confused i am lol |
emerygt350 |
Sep 18 2022, 04:35 AM
Advanced Member Group: Members Posts: 2,087 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Try checking the cone screw where the rod enters the tunnel. If loose it will cause slipping on rotation, often causing you to lose 4/5.
ChrisFoley |
Sep 18 2022, 05:47 AM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
emerygt350 |
Sep 18 2022, 07:36 AM
Try checking the cone screw where the rod enters the tunnel. If loose it will cause slipping on rotation, often causing you to lose 4/5. Tailshift - no cone screws. Really? Wow. I guess that's good, since they can't come loose, but bad on that it's such an easy fix... |
ChrisFoley |
Sep 18 2022, 08:44 AM
Try checking the cone screw where the rod enters the tunnel. If loose it will cause slipping on rotation, often causing you to lose 4/5. Tailshift - no cone screws. Really? Wow. I guess that's good, since they can't come loose, but bad on that it's such an easy fix... Actually I was wrong, there is one at the base of the shift lever. |
Lo-Fi Version | Time is now: 6th May 2024 - 10:18 PM |
