> Idle hunting and the T1 sensor 74 2.0
scottsilvertt
post Sep 19 2022, 03:25 PM
scottsilvertt
My car is running good, stock FI.
After, New rings, and 1. getting injectors working(was brain) and 2. spark (too much corrosion on dizzy shaft, was sanding down the point adjustment, so I polished the shaft.) and 3. I forgot to attach rear ground strap, (so the ground was the parking brake cable) 4. New ignition switch.
Anyway its good now,
Except for that idle hunt.
Engine cold hard to hold idle.
Cold , If I unplug sensor T1 on top of intake box, it doesn’t hunt.
But when warm it becomes high idle.
If I unplug at warm, idle is prefect.
How do you fix this permanently?
Scott
- Lo-Fi Version Time is now: 13th April 2026 - 09:23 PM
