Trunk lock position, Which way does it go? |
mxkinn01 |
Sep 19 2022, 04:39 PM
Member Group: Members Posts: 228 Joined: 18-June 17 From: Las Vegas, NV Member No.: 21,195 Region Association: Southwest Region |
It was pointed out to me at the RRC my key direction was incorrect. I installed horizontal = unlocked and vertical = locked. Is that right or should it be the other way around?
Thanks Mike |
914werke |
Sep 19 2022, 06:21 PM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
was it diss & reassembled? My recollection is that the lock body is "keyed" to a notch on the sheet metal so if never monkeyed with should be orientated as intended?
mxkinn01 |
Sep 19 2022, 07:04 PM
was it diss & reassembled? My recollection is that the lock body is "keyed" to a notch on the sheet metal so if never monkeyed with should be orientated as intended? Yes it was taken apart and cleaned. It was missing the spring and I replaced it but couldn't remember which way it went. I had it the other way then changed it after I was told it was wrong. Now I'm told it's wrong again. So just wondering which way it came from the factory. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:33 AM |
