74 2.0 ECU repair, seeking help or source |
scottsilvertt |
Sep 20 2022, 07:50 AM
scottsilvertt Group: Members Posts: 66 Joined: 17-May 06 From: South East USA Member No.: 6,019 Region Association: South East States |
Hi,
I think I burned up my good working 1974 2.0 ecu. I reversed the wires on my coil, about that same time my ECU went out. I had an extra 1973 ecu, and that is in the car and running. Are there places to send the ECU to for repair? I’m going to open it and see if I can see obvious burn points. |
mihai914 |
Sep 20 2022, 08:12 AM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
You can also post a WTB in the classifieds. I'm sure a couple of people have some lying around.
StarBear |
Sep 20 2022, 08:45 AM
Senior Member Group: Members Posts: 1,849 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Not sure, but one or two here ( @jeffbowlsby and George at AA) can do testing but don’t know about that. Believe unit must be in a vehicle for testing.
Haven’t found anyone who can test a 1.8 ecu. (IMG:style_emoticons/default/sad.gif) |
mgphoto |
Sep 20 2022, 09:47 AM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
F.I.C. (Fuel Injection Corp.) used to rebuild them but I believe they stopped a few years ago.
Best bet is to place a WTB ad here and over at the samba. If you can find an entire system from someone who is going to carbs you will have all the necessary parts. |
dr914@autoatlanta.com |
Sep 20 2022, 09:53 AM
914 Guru Group: Members Posts: 7,816 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
specialized ecu repair, oakland park florida
Hi, I think I burned up my good working 1974 2.0 ecu. I reversed the wires on my coil, about that same time my ECU went out. I had an extra 1973 ecu, and that is in the car and running. Are there places to send the ECU to for repair? I’m going to open it and see if I can see obvious burn points. |
914_teener |
Sep 20 2022, 01:06 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
specialized ecu repair, oakland park florida Hi, I think I burned up my good working 1974 2.0 ecu. I reversed the wires on my coil, about that same time my ECU went out. I had an extra 1973 ecu, and that is in the car and running. Are there places to send the ECU to for repair? I’m going to open it and see if I can see obvious burn points. (IMG:style_emoticons/default/agree.gif) I sent mine here years back. If there is nothing wrong....a small service fee plus shipping...which seems to be really expensive nowdays. |
Geezer914 |
Sep 21 2022, 08:33 AM
Geezer914 Group: Members Posts: 1,382 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I had mine checked and they only charged $35.
StarBear |
Sep 22 2022, 01:37 PM
Looks like they don't do ECUs for 1.8L.
Anyone know who does? |
JeffBowlsby |
Sep 22 2022, 09:40 PM
914 Wiring Harnesses Group: Members Posts: 8,477 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have the EFI Assoc 8100 Ljet tester (as well as the EFI Assoc 9100 DJet tester + 3 other Djet testers) to test all functions of the ECUs. They are made as shop diagnostic tools, and require the ECU to be installed within a full FI system with all its components to run the test protocols. They test the function of the entire system and each component.
I don’t have a 1.8L to use as a test mule but I can test all the 1.7L and 2.0L ECUs, MPSs and the other Djet components. |
Lo-Fi Version | Time is now: 25th April 2024 - 04:08 AM |
