What is this gap?, And why would it be dripping fluid? |
mjsdt914 |
Sep 21 2022, 09:24 AM
Newbie Group: Members Posts: 27 Joined: 10-August 21 From: Whitefish, Montana 59937 Member No.: 25,791 Region Association: Rocky Mountains |
This gap is at the front of the transmission where it mates with the engine (as seen from below).
Does it have a name? Am I missing a plug for this hole? Any ideas why it would be dripping fluid? Please advise. Thanks! Attached image(s) |
JamesM |
Sep 21 2022, 05:31 PM
Senior Member Group: Members Posts: 1,904 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
This gap is at the front of the transmission where it mates with the engine (as seen from below). Does it have a name? Am I missing a plug for this hole? Any ideas why it would be dripping fluid? Please advise. Thanks! Are you actually getting a drip of fluid on the ground or are you just observing the blackness on the case below the hole? If there is nothing on the ground under the car I wouldn't worry about it, above that hole is your clutch so there will always be some level of black dust existing there. If you are getting liquid on the ground then its either the trany or engine seal there. |
mjsdt914 |
Sep 22 2022, 01:32 PM
This gap is at the front of the transmission where it mates with the engine (as seen from below). Does it have a name? Am I missing a plug for this hole? Any ideas why it would be dripping fluid? Please advise. Thanks! Are you actually getting a drip of fluid on the ground or are you just observing the blackness on the case below the hole? If there is nothing on the ground under the car I wouldn't worry about it, above that hole is your clutch so there will always be some level of black dust existing there. If you are getting liquid on the ground then its either the trany or engine seal there. Not 'leaking' nor leaving a puddle ... more like 'dripping' a few drops ... noticed after I started to clean the undercarriage ... not terribly concerned yet as it may be left over gunk ) |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:49 PM |
