Side Marker Seals 914 Rubber, Might Be Too Large |
914Sixer |
Sep 22 2022, 12:58 PM
914 Guru Group: Members Posts: 8,844 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Going to need to send mine back. Too large, kept falling off. Installed them, big humps. Showing pictures of factory, earlier 914 Rubber and one I got Monday.
Attached image(s) |
76-914 |
Sep 22 2022, 02:34 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,455 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
That's not good! I'm sure that Mark @mikey914 will make it good. Odd, you'd expect the first one to be the dud. Not the second run. (IMG:style_emoticons/default/confused24.gif)
Mikey914 |
Sep 22 2022, 02:53 PM
The rubber man Group: Members Posts: 12,622 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Check the profile of the rubber there are 2 ways to install it.
The profile has a small step for the lens that makes it fit perfectly around the lens. I install this 1st then install the base into the other slot. Doing so you can make sure you have it in the correct slot. The rubbing is an indication that the base is not fitting on the rubber and getting caught on the step. If you look closely the profile looks something like this, Attached image(s) |
914Sixer |
Sep 23 2022, 06:22 AM
Double checked install, they are still too big.
Attached image(s) |
sixnotfour |
Sep 23 2022, 09:34 AM
914 Wizard Group: Members Posts: 10,392 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
What altitude due you live at ??...Bag of chips syndrome..
914Sixer |
Oct 8 2022, 03:42 PM
Now resolved, new correct size gaskets arrived today. Shout out to Mark for getting on this.
Attached image(s) |
MM1 |
Oct 8 2022, 05:17 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
Good job Mark and Mark for quick feedback and response!
Ansbacher |
Oct 8 2022, 08:25 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
And that's why smart 914 owners buy from 914Rubber. Even when they get it wrong they make it right in the end.
Ansbacher (no affiliation) |
Lo-Fi Version | Time is now: 28th March 2024 - 04:18 PM |
