How to empty gas tank ro replace fuel pump, pump is under gas tank...maybe pump out from top? |
second wind |
Sep 29 2022, 02:45 PM
Senior Member Group: Members Posts: 855 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hey gang...replacing fuel pump mounted next to steering rack....how can I empty the gas tank before I start the job? From the bottom doesn't work for me...
Thank you very much! gg |
eric9144 |
Sep 29 2022, 04:17 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
If you have two sets of needle nose Vice Grips there's an easy way...
Get some fuel lines and essentially cover both sides of the needle nose with the fuel line (like an insulator)--you can then use those to clamp the lines shut on both sides of the fuel pump. It might drip a little, but it works really well and avoids all that draining/siphoning and when you get things back together you're able to test and be done with the whole thing quickly. |
second wind |
Sep 29 2022, 06:10 PM
If you have two sets of needle nose Vice Grips there's an easy way... Get some fuel lines and essentially cover both sides of the needle nose with the fuel line (like an insulator)--you can then use those to clamp the lines shut on both sides of the fuel pump. It might drip a little, but it works really well and avoids all that draining/siphoning and when you get things back together you're able to test and be done with the whole thing quickly. I'm really liking this idea!! Gotta' love 914 World....so the fuel line over the needle nose is to protect the live fuel lines, right? This job is getting easier by the minute. Thank you very much! gg |
Lo-Fi Version | Time is now: 19th May 2024 - 09:43 AM |
