How to empty gas tank ro replace fuel pump, pump is under gas tank...maybe pump out from top? |
second wind |
Sep 29 2022, 02:45 PM
Senior Member Group: Members Posts: 855 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hey gang...replacing fuel pump mounted next to steering rack....how can I empty the gas tank before I start the job? From the bottom doesn't work for me...
Thank you very much! gg |
Olympic 914 |
Sep 29 2022, 03:51 PM
Group: Members Posts: 1,670 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
fiacra |
Sep 30 2022, 02:16 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 329 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
I have used a HF battery powered transfer pump. Pumping the gas into cans sitting in the front trunk. You have to take off the tank inlet to fit the pump down in there. Agreed. This is what I have done in the past and it works well. Clay's method sounds like it would work well also, just a bit more work. Bottom line, using something to pump the gas out works best for me. |
ClayPerrine |
Oct 1 2022, 06:45 AM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I have used a HF battery powered transfer pump. Pumping the gas into cans sitting in the front trunk. You have to take off the tank inlet to fit the pump down in there. Agreed. This is what I have done in the past and it works well. Clay's method sounds like it would work well also, just a bit more work. Bottom line, using something to pump the gas out works best for me. I take the transfer pump setup when traveling long distances with the 914 on the trailer. It has two purposes. If the pump in my 914 fails, the one in the transfer pump setup is the same as the one in the car, so I can swap them. The second reason is that I keep the 914 tank full while it is on the trailer. If we get in the middle of nowhere and the low fuel light comes on, I can always transfer the gas from the 914 to the tow vehicle. The pump, hoses and wires don't take up much space, and it cheap insurance. Clay |
Lo-Fi Version | Time is now: 19th May 2024 - 10:06 AM |
