what were they thinking, transmission issue never seen |
doobie123 |
Oct 4 2022, 01:47 PM
Member Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi ya'll
I'm working on a 1975 914, 1.8, 5 Spd it needs a clutch so I removed the engine and trans so I could give them both a bath and service the engine bay too. while cleaning the trans I discovered what you see in the attached photos. on top of a big blob of silicone caulk was a smaller sized but no less of a blob of JB weld. underneath that was what is shown in the pic of what looks like a washer and a brass disc. they are also spinning in that hole the location of this "fix" is at he very back of the trans where the trans bolts to a cross brace which bolts to the the frame, just above the speedo drive in the center of what looks like a cover separate but bolted to the trans case. it was obvious it was put there to stop a leak as that area was covered with dirt and grease. so my questions are what should that cover look like? what is the correct fix? can that cover just be removed for inspection/repair/replacement without having to dismantle the trans? also, any info anyone has on something like this. thanks in advance. |
doobie123 |
Oct 4 2022, 06:47 PM
thanks for the replies. will that case back be a straight remove and replace assuming there is no other damage?
interesting about the #s. i'll be calling auto atlanta for a replacement. i'll post anything i learn on that. |
wonkipop |
Oct 4 2022, 11:04 PM
Advanced Member Group: Members Posts: 4,284 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
thanks for the replies. will that case back be a straight remove and replace assuming there is no other damage? interesting about the #s. i'll be calling auto atlanta for a replacement. i'll post anything i learn on that. just stuck my head up in there on mine. same part # as you. third group of numbers is 302 like your casting. its a 74 1.8 here is PET catalogue. another typo to add to others that have been found. |
Lo-Fi Version | Time is now: 12th May 2024 - 11:17 AM |
