what were they thinking, transmission issue never seen |
doobie123 |
Oct 4 2022, 01:47 PM
Member Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi ya'll
I'm working on a 1975 914, 1.8, 5 Spd it needs a clutch so I removed the engine and trans so I could give them both a bath and service the engine bay too. while cleaning the trans I discovered what you see in the attached photos. on top of a big blob of silicone caulk was a smaller sized but no less of a blob of JB weld. underneath that was what is shown in the pic of what looks like a washer and a brass disc. they are also spinning in that hole the location of this "fix" is at he very back of the trans where the trans bolts to a cross brace which bolts to the the frame, just above the speedo drive in the center of what looks like a cover separate but bolted to the trans case. it was obvious it was put there to stop a leak as that area was covered with dirt and grease. so my questions are what should that cover look like? what is the correct fix? can that cover just be removed for inspection/repair/replacement without having to dismantle the trans? also, any info anyone has on something like this. thanks in advance. |
930cabman |
Oct 7 2022, 12:03 PM
Advanced Member Group: Members Posts: 3,055 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Over a half century many things can happen, including DAPO's ( and mechanic's) who sometimes in desperation do a bailing wire repair to get them home and never gets corrected properly.
Lo-Fi Version | Time is now: 13th May 2024 - 12:43 PM |
