Front trunk lock installed on rear trunk??? |
Kerrys914 |
Jul 25 2003, 09:41 AM
HAs anyone thought of installing a front trunk lock system on the reat trunk? I am looking for a better way to deal with the "Rear reflector" addition.
The front lock is designed for use with a cable and could be adapted easier to be used with an emergency system. Thoughts? Anyone have an extra set of front locks? Cheers Kerry |
URY914 |
Jul 25 2003, 09:46 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,562 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
You would have to make the lid spring loaded so it tops up when you pull the cable.
Could be done...try one of those shock kits that holds the lid up. Paul |
914werke |
Jul 25 2003, 10:29 AM
"I got blisters on me fingers" Group: Members Posts: 10,058 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Actually in a different thread I mentioned I still have one of the cable release latched in lue of the solinoid unit.
I just couldnt come up with a pull cable for it (the existing one was broke) I had never thought of reusing the front hood release cable/handle/guide tube? Pretty good idea. The kicker is OE mechinism uses a solid wire pinched by a bolt in the front at the latch. The latch I have used a multi strand cable with a small leaded end? Here is a bad Pic: Attached image(s) |
Kerrys914 |
Jul 25 2003, 10:59 AM
Lo-Fi Version | Time is now: 14th May 2024 - 03:10 AM |
