Hole in Throttle Body Flap, Needed or Not |
914Sixer |
Oct 4 2022, 08:32 PM
So I bought a big bore throttle body a while back and just got around to comparing it to the stock one. Stock body has a hole in it. What is the function of the hole? To keep the idle stable? Do I need to put one in big bore? Inquiring minds want to know.
Attached thumbnail(s) |
914Sixer |
Oct 12 2022, 05:42 AM
Using D-Jet on with MPS tuned by Jeff B. Engine is 2056 with Elgin cam with slightly more lift and Hoffman heads.
r_towle |
Oct 12 2022, 06:17 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
ClayPerrine |
Oct 13 2022, 01:40 PM
Life's been good to me so far..... Group: Admin Posts: 15,463 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You do not need a larger throttle body all the way up to 2.4 on djet. Tuned on a dyno Fact If it is a 1.7L D-Jet, you need a bigger throttle body. The 1.7L throttle body is a little bitty bugger. If it is a 2.0L D-Jet, you don't necessarily need a bigger throttle body, but it can make it a bit more peppy. |
Lo-Fi Version | Time is now: 16th May 2024 - 09:45 AM |
