Hole in Throttle Body Flap, Needed or Not |
914Sixer |
Oct 4 2022, 08:32 PM
914 Guru Group: Members Posts: 8,882 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
So I bought a big bore throttle body a while back and just got around to comparing it to the stock one. Stock body has a hole in it. What is the function of the hole? To keep the idle stable? Do I need to put one in big bore? Inquiring minds want to know.
Attached thumbnail(s) |
DRPHIL914 |
Oct 13 2022, 03:34 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Using D-Jet on with MPS tuned by Jeff B. Engine is 2056 with Elgin cam with slightly more lift and Hoffman heads. You do not need a larger throttle body all the way up to 2.4 on djet. Tuned on a dyno Fact If it is a 1.7L D-Jet, you need a bigger throttle body. The 1.7L throttle body is a little bitty bugger. If it is a 2.0L D-Jet, you don't necessarily need a bigger throttle body, but it can make it a bit more peppy. i have a similar set up , 2.1 9.5compression, d-jet, and i installed this summer a 49.5mm throttle body, bored out stock '73 2.0 TB from Chris Foley, I can tell you it does make a difference from mid to high end for sure . With the modified cam, conter balanced crank and new heads with larger valves ported and polished, it all makes a difference so with these other changes, more air coming in helps on that top end where it felt before like it was not getting enough. Id like to do a before/after dyno but i dont have that ability. Seat of the pants evaluation says it does. |
Lo-Fi Version | Time is now: 16th May 2024 - 07:16 AM |
