123 Ignition App Dashboard Accuracy, Blue Tooth Version |
Highland |
Oct 7 2022, 02:58 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Wondering if anyone can comment on the accuracy of 123 Ignition's dashboard gauge accuracy. Is the Bluetooth connection causing error?
When I'm at steady idle, my stock Tach reads about 50~100 rpm higher and at steady cruise (3000 rpm) my Tach reads about 200 rpm higher. Also curious about amp, V, vacuum and oil temp gauges. Is the amp only for coil/ignition load? |
Lo-Fi Version | Time is now: 17th May 2024 - 03:58 AM |
