FS: 914 Race Car, 2.5 liter 6 Race Car for sale |
914racer |
Oct 16 2022, 08:01 PM
Newbie Group: Members Posts: 16 Joined: 4-January 11 From: Cincinnati, OH. Member No.: 12,564 Region Association: None |
FOR SALE 914-6 (CONVERSION)
RACE CAR / ULTIMATE DE CAR Raced in PCA GT5, PCA Vintage class, NASA, PBOC 5 bolt hubs Forgeline 2 piece wheels - extra sets wheels available Elephant suspension bushings Front oil cooler vent through top of front trunk Fuel Cell Lexan windshield Onboard fire system -AFFF Front oil tank - Coleman AIM MXL digital dash Race seat - Kirkey (driver) and MOMO (passenger) Custom roll cage connects the front torsion bar attachment to gear box mount Driver's Intrusion Bar - removable to allow access to under dash and pedals Custom cable shifter 23mm master cylinder Wilwood brakes Fiberglass hood, top and trunk lid, front and rear bumpers Rear wing AMB Transponder - hard wired Custom stiffing of the rear swing arms to avoid adding weight Koni shocks - Yellow adjustable Adjustable rear spring perches 180# rear springs Aeroquip oil, fuel and brake lines Bump Steer Kit - Elephant Racing Torsion Bar Dia:21mm Detachable Fender Flares MOCAL Oil Thermostat MOMO Steering Wheel w/ quick disconnect Adjustable from sway bar Schroth 6 point harness - expired for racing Car weights about 2000 lbs. MOTOR 2.5 liter 6 cylinder 40 mm PMO 86 mm pistons 2.7 Crank 2.4 7R case Shuffle pinned (Ollies) Line bored to 0 (Ollies) Twin plug 11.1 compression ratio - runs on 93 octane Crank fire - Electromotive Custom carb linkage Exhaust headers ceramic metalic coated Heads - ported and polished Last race 11/13/17 @ Pitt - 4 race weekends since rebuild GEAR BOX GT Racing Guard limited slip Short gears 1-A, 2-F, 3-KA (flipped) ZD, 4-Q, 5-U Gearbox oil cooler with electric pump and fan |
Lo-Fi Version | Time is now: 2nd May 2024 - 04:53 AM |
