Stock tire, Manufacturer? |
Oct 16 2022, 09:02 PM
Custom Member Group: Members Posts: 24,563 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Street, stock, 15’s
What brand are people finding out there that are a good tire for the car? |
Van B |
Oct 16 2022, 09:11 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
https://www.tirerack.com/tires/vredestein-sprint-classic
I’m going with these in a 185 because it should correct my speedo error. But you can get them in a 165 as well. Otherwise you can get reproductions from Coker Tire |
wonkipop |
Oct 17 2022, 03:40 AM
Advanced Member Group: Members Posts: 4,245 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
i'm running michelin XAS 165s.
f-en fantastic. made of something way softer than back in the day. stick like shite to a blanket. (IMG:style_emoticons/default/beer.gif) cost an arm and a leg down here near the south pole. but while it hurt the bank balance i am not complaining about the ......result. |
930cabman |
Oct 17 2022, 06:20 AM
Advanced Member Group: Members Posts: 3,000 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I recently purchased a set of Nexen 175/65 15 from my local guy for $80. Nothing fancy, but they give a nice ride, probably close to stock
friethmiller |
Oct 17 2022, 07:16 AM
Member Group: Members Posts: 463 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
I've got about 4,000 miles on a set of BF Goodrich Advantage T/As (195/65R15) that I purchased on sale at Costco about a year ago. I believe these closely match the original tire size but just wider. I must say that I'm really impressed. They're very quiet yet perform very well. Longevity has yet to be proven. However, at that kind of mileage, it'll take me 10 years to get to 40,000 miles (IMG:style_emoticons/default/huh.gif)
live free & drive |
Oct 17 2022, 02:27 PM
Member Group: Members Posts: 154 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
It looks like Vredestein has introduce a new v rated performance tire in 195/60-15 size. It kind of looks like the old Pirelli P600. This might be a good choice, although not many reviews or ratings yet:
https://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes |
VaccaRabite |
Oct 17 2022, 02:47 PM
En Garde! Group: Admin Posts: 13,423 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
It looks like Vredestein has introduce a new v rated performance tire in 195/60-15 size. It kind of looks like the old Pirelli P600. This might be a good choice, although not many reviews or ratings yet: https://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes The concerns about keeping the tires in cold conditions is a concern with these tires. QUOTE Note: Tires exposed to temperatures of 20 degrees F (-7 degrees C) or lower must be permitted to gradually return to temperatures of at least 40 degrees F (5 degrees C) for at least 24 hours before they are flexed in any manner, such as by adjusting inflation pressures, mounting them on wheels, or using them to support, roll or drive a vehicle. Looks like with these tires you pretty much have to the keep the car on jack stands over the winter. Zach |
ClayPerrine |
Oct 17 2022, 02:56 PM
Life's been good to me so far..... Group: Admin Posts: 15,410 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I've got about 4,000 miles on a set of BF Goodrich Advantage T/As (195/65R15) that I purchased on sale at Costco about a year ago. I believe these closely match the original tire size but just wider. I must say that I'm really impressed. They're very quiet yet perform very well. Longevity has yet to be proven. However, at that kind of mileage, it'll take me 10 years to get to 40,000 miles (IMG:style_emoticons/default/huh.gif) We have the same tires on the Factory six. They are good tires, but definitely not in the same performance class as a high performance summer only tire. They will squeal a lot when you get close to the limit. But they are a really good tire for a driver. If you are looking for max performance, look for the tire used on a Miata for autocross. They use the same 15 inch rims on a Miata. Hope that helps! Clay |
JamesM |
Oct 18 2022, 08:39 AM
Senior Member Group: Members Posts: 1,888 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
It looks like Vredestein has introduce a new v rated performance tire in 195/60-15 size. It kind of looks like the old Pirelli P600. This might be a good choice, although not many reviews or ratings yet: https://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes The concerns about keeping the tires in cold conditions is a concern with these tires. QUOTE Note: Tires exposed to temperatures of 20 degrees F (-7 degrees C) or lower must be permitted to gradually return to temperatures of at least 40 degrees F (5 degrees C) for at least 24 hours before they are flexed in any manner, such as by adjusting inflation pressures, mounting them on wheels, or using them to support, roll or drive a vehicle. Looks like with these tires you pretty much have to the keep the car on jack stands over the winter. Zach I put a set on my Bumblebee project last month, Wanted to go with the 165s but they were backordered a few months so went with the 175s. Cool vintage look, proper sidewall height, and while I havent gone to crazy yet (still sorting the car out) the little i have pushed them they feel pretty sticky. It does feel like an autocross compound on a narrow, high sidewall, vintage tread tire. Thankfully my garage is heated. |
Jett |
Oct 18 2022, 08:57 AM
Senior Member Group: Members Posts: 1,635 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Have XWX with the dog bone pattern from Michelin. Got them from Coker.
Pretty expensive but nice ride. Attached image(s) |
76-914 |
Oct 18 2022, 09:05 AM
Great thread!
friethmiller |
Oct 18 2022, 09:10 AM
We have the same tires on the Factory six. They are good tires, but definitely not in the same performance class as a high performance summer only tire. They will squeal a lot when you get close to the limit. But they are a really good tire for a driver. If you are looking for max performance, look for the tire used on a Miata for autocross. They use the same 15 inch rims on a Miata. Hope that helps! Clay (IMG:style_emoticons/default/agree.gif) My bumblebee project might be getting a set of Vredesteins when I finally finish it in about 5 years (IMG:style_emoticons/default/blink.gif) |
friethmiller |
Oct 18 2022, 09:16 AM
Has anybody tried the Michelin XAS | 165VR15 tires? Cheaper than the XWXs but still expensive... because Michelin makes them (IMG:style_emoticons/default/smile.gif)
Update: Just saw the post from above. Interesting. Might be a good option for an original sized tire. |
mgphoto |
Oct 18 2022, 09:59 AM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
930cabman |
Oct 18 2022, 10:55 AM
VaccaRabite |
Oct 18 2022, 11:08 AM
I put a set on my Bumblebee project last month, Wanted to go with the 165s but they were backordered a few months so went with the 175s. Cool vintage look, proper sidewall height, and while I havent gone to crazy yet (still sorting the car out) the little i have pushed them they feel pretty sticky. It does feel like an autocross compound on a narrow, high sidewall, vintage tread tire. Thankfully my garage is heated. I need tires for my car and I've been looking at these for a while now. But I get worried about that damn disclaimer. I actually drive my car on crisp days. I'd need to keep 2 sets of wheels for the 914. :-/ I guess I need to suck it up and just get another set of all seasons. :-( Zach |
rgolia |
Oct 18 2022, 01:17 PM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
My tires are about 10 yrs old. Is it time for a change? Currently running 185/70s sprint classics. How about these as a replacement?
Pirelli P4 PERSIST AS PLUS - SIZE: 195/65R15 |
Van B |
Oct 18 2022, 01:38 PM
to all those running 195/65-15, I think you're giving away miles on your odometer. I clocked mine at 5mph faster than GPS actual.
Zach, I'm all in on the Vred's. I wouldn't worry too much about the temperature restriction unless you're actually in freezing conditions. My Michelin supersport tires have the same caution, but I routinely drive the 911 on crisp winter mornings. They never come fully up to temp, but they do generate grip after a few miles of driving. |
GeorgeRud |
Oct 18 2022, 06:20 PM
to all those running 195/65-15, I think you're giving away miles on your odometer. I clocked mine at 5mph faster than GPS actual. Zach, I'm all in on the Vred's. I wouldn't worry too much about the temperature restriction unless you're actually in freezing conditions. My Michelin supersport tires have the same caution, but I routinely drive the 911 on crisp winter mornings. They never come fully up to temp, but they do generate grip after a few miles of driving. The rolling radius of the 195/65-15 tires is 25”, vs 25.1 for the 165 size. The speedometers have always been optimistic, but the odometer should still be quite accurate. |
Oct 18 2022, 08:33 PM
My tires are about 10 yrs old. Is it time for a change? Currently running 185/70s sprint classics. How about these as a replacement? Pirelli P4 PERSIST AS PLUS - SIZE: 195/65R15 Tires are only safe up to six years. After that, in high temp highway situations, the can delaminate and cause a ton of body, fender damage as they just seem to fall apart at speed. One time, my FIL…i trailered his old Volvo home….it was not cheap or pretty to fix. My motto, tires are cheaper than bodywork. I just replaced some old tires on my 911 and the guy at the local shop argued the old ones are perfectly good. I told him go ahead…they are free. Rich |
Lo-Fi Version | Time is now: 25th April 2024 - 05:48 PM |
