Oily Clutch Question--914-6 2.7, Moving forward...maybe it'll breathe again Sunday... |
Robarabian |
Oct 17 2022, 04:50 PM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
Working on what I will now call Pandoras 914-6, I have managed to clean everything, find my #8 seal area leak and am dealing with it.
I pulled the clutch cause it looked a little oily and I located what you see in the photos. On a 914-4 I know there is an alignment dowel, but on this crankshaft, there looks to be a small metal plug. In that area, there is oil, and it matches the flywheel. I noticed there is no felt washer like on the 4 cylinder...and obviously the flywheel ring is thicker so there probably is no felt seal. The main seal seems pretty dry, it appears to be coming from this hole. Thoughts on this issue, I have never seen this before. Fixes? Thanks as always Attached thumbnail(s) |
Robarabian |
Oct 17 2022, 04:51 PM
Superhawk996 |
Oct 17 2022, 11:34 PM
914 Guru Group: Members Posts: 5,827 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Leaky crankshaft oil galley plug.
Fixes range from drill and tapped plugs to cleaning with brake clean and trying JB weld. I’ve also heard of aluminium plugs that are installed as a cold press fit into a heated crank - the theory being that once installed as steel crank heats up, the aluminium expands faster than steel increasing the sealing / press fit interference. In all transparency - I have not had to address this on a 911 crank. Ollie’s did my crank but engine hasn’t been assembled. If I recall - Bruce Anderson book doesn’t recommend pulling the crank plugs. I don’t see how you can guarantee no debris in the crank galley without removing the plugs. It’s a catch 22 IMHO. Hopefully I don’t end up in same situation when I finally get my engine assembled and running. |
Robarabian |
Oct 18 2022, 07:58 AM
@superhawk996 thanks for the info. I think I will leave the plug there and try to epoxy / JB weld unless others chime in with another idea.
I did find other crankshafts online that have the same plug as mine in there, so mine is not unique. It must be an aluminum plug that just is not sealing properly. Good luck with yours! Rob |
lesorubcheek |
Oct 18 2022, 08:39 AM
Member Group: Members Posts: 193 Joined: 21-April 21 From: Florida Member No.: 25,463 Region Association: South East States |
My only experience with a crank plug was about 3 years ago on one of our mowers that used a Kohler Courage twin (hey, it is air cooled). It was cutting fine, then all of a sudden began acting like the engine was overloaded. Thought I'd wrapped up something on the blades, so disengaged and started driving toward the shop. Halfway there the engine suddenly locked up. Upon disassembly, found the crank had eaten away the bearing surface on the aluminum block and basically fused to the melted glob that resulted from the friction. Turned out a plug on the crankshaft had worked its way out, and when it did, no oil pressure to the front bearing surface. I was able to salvage the crank by dissolving the fused-on aluminum with muratic acid. Amazingly the pistons were still OK, just needed a new block and a few odds and ends. Tapped and plugged the port on the crank with a brass plug and it's been running fine ever since. Last cutting was a couple of weeks ago.
Everything Superhawk996 said is right on with what I've researched about crank plugs. If it's seeping now, it will only get worse. It is under pressure and if it blows out, well, it's not good. If it were mine, and was 98% sure the plug was leaking, that plug would be removed, hole tapped, thorough cleaning of the oil galley, and a threaded plug installed. I do have a bias obviously from the previous experience. It may be preferred in the community to use a press-fit plug in this situation. Dan |
Superhawk996 |
Oct 18 2022, 09:02 AM
The good news is that the plug can’t blow out since it is backed up by the flywheel.
I’m just feeling bad knowing that this “project” started out with as a suspected front seal leak that turned into the dreaded #8 bearing leakage, that is now crank galley plug leakage. (IMG:style_emoticons/default/headbang.gif) On the flip side (IMG:style_emoticons/default/first.gif) for dropping the engine and trying to address the leaks rather than just smearing RTV on the case and hoping for a miracle. (IMG:style_emoticons/default/idea.gif) that galley plug appears to be peened. Is there a way to back it up with a long punch running into the oil galley and re-peen it to make it tighter? Disregard: that would involve splitting the case . . . But if you do split case to address #8 then that idea might pan out |
Robarabian |
Oct 18 2022, 11:01 AM
Thanks guys.
I believe it is not a plug but an actual solid dowel that is pressed in. From some diagrams I have seen and looking up replacement crank main dowel pins it looks like a pretty solid plug. Ill gently scratch at it with a scribe to see if it is aluminum or steel but the replacements all look to be steel. If that is the case, I can probably get it out easier and press in a steel one. I have been cursing Porsche engineers the past few days. Why leave this as an "open hole" in the crank? The Type 4 has metal behind the dowel.... Unless it was drilled through by the rebuilder when it was rebuilt and plugged. The flywheel does not have space for a dowel, but I think the larger engined cars or the dedicated 911's with more bolt flywheels did. Yes, the flywheel keeps it from backing out for sure. I'll keep "plugging" away at this and see what I can discover. Rob |
Superhawk996 |
Oct 18 2022, 11:07 AM
Thanks guys. I believe it is not a plug but an actual solid dowel that is pressed in. discover. Rob Yup - same difference (IMG:style_emoticons/default/biggrin.gif) Just like OEM galley plugs on the case. I didn’t necessarily mean to imply a threaded plug. For whatever reason I thought yours might be brass but maybe I’m just seeing yellow tint in the photo as amber color of oil on it. To get them out it’s usually a drill and tap operation and then the slide hammer. At least yours has a nice dimple to help center the pilot drill if you go the remove & replace route. |
Superhawk996 |
Oct 18 2022, 11:20 AM
Why leave this as an "open hole" in the crank? Rob It’s not an open hole . . . It’s plugged (IMG:style_emoticons/default/happy11.gif) On a serious note, drilling and cleaning a blind hole is a bad plan from an engineering and manufacturing point of view. Therefore the galley is drilled all the way through, cleaned and then plugged. Very common. Really no different than plugging holes on the case, carburettors, cam tower spray bars, etc. I suspect whoever did yours didn’t press it or peen it properly. Not sure if that is OEM or a reworked crank. Like I said, when my crank came back from Ollie’s I could see all galley plugs had been removed and replaced. |
rudedude |
Oct 18 2022, 07:52 PM
Senior Member Group: Members Posts: 509 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
If you dont replace it, clean it really well and try some wicking loctite before jb weld over it. Mine were leaking and I made new plugs and put in with 574 case sealant and I haven't seen any evidence of new leaking.
It also doesn't look like the seal is properly installed. |
Robarabian |
Oct 18 2022, 08:03 PM
Thank you for that insight. The seal looks funny in the photo but it is ok. Im leaving it in till I solve this, then I will rip it out and install a brand new one that I have in the box.
My other alternative is to clean it real well, bust out the mig welder and seal it with weld and grind it flat. Wont leak then, but I am seeking less extreme alternatives first. (IMG:style_emoticons/default/smile.gif) If you dont replace it, clean it really well and try some wicking loctite before jb weld over it. Mine were leaking and I made new plugs and put in with 574 case sealant and I haven't seen any evidence of new leaking. It also doesn't look like the seal is properly installed. |
Superhawk996 |
Oct 18 2022, 08:09 PM
My other alternative is to clean it real well, bust out the mig welder and seal it with weld and grind it flat. Wont leak then, but I am seeking less extreme alternatives first. That is crazy talk. There are more bad things that could come of that than are worth the risk. (IMG:style_emoticons/default/sad.gif) |
sixnotfour |
Oct 20 2022, 11:09 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Flywheel end is # 1 Bearing,, Fan end is #8
Superhawk996 |
Oct 20 2022, 11:54 AM
Robarabian |
Oct 20 2022, 01:16 PM
Carbide drills ordered. Will drill it, tap it and try to yank it out hopefully this weekend. I will then re-install a new plug with the appropriate wicking loctite.
Oh the joys of old cars. At least it is out of the car and I can get to it pretty easy. Now to take time, be patient and move slow. Thanks for all the advice everyone! Flywheel end is # 1 Bearing,, Fan end is #8 Agreed. Rob’s project also has a leaky #8 o-ring sealing problem (separate post) in addition to this leak on #1 end that is really a leaking crankshaft galley plug. |
sixnotfour |
Oct 20 2022, 01:17 PM
Flywheel end is # 1 Bearing,, Fan end is #8 Agreed. Rob’s project also has a leaky #8 o-ring sealing problem (separate post) in addition to this leak on #1 end that is really a leaking crankshaft galley plug. Missed it.. (IMG:style_emoticons/default/beerchug.gif) |
porschetub |
Oct 20 2022, 01:21 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
It also doesn't look like the seal is properly installed. (IMG:style_emoticons/default/agree.gif) not sure about others on here put the VR brand seal was a poor fit in my case ,very loose ,pulled it out and replaced with from what I can remember was an Elring or Sabo,not 100% sure. Put the replacement in and it fitted like it should ,had no leaks when I pulled the g/box to replace shaft seal. I would use JB weld as mentioned...seems like the only "safe" solution. |
Justinp71 |
Oct 20 2022, 04:44 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
If you use JB weld just make sure you don't use so much that it is between the crankshaft and flywheel mating surface. This would cause the flywheel to be off balance. |
porschetub |
Oct 20 2022, 09:42 PM
Carbide drills ordered. Will drill it, tap it and try to yank it out hopefully this weekend. I will then re-install a new plug with the appropriate wicking loctite. Oh the joys of old cars. At least it is out of the car and I can get to it pretty easy. Now to take time, be patient and move slow. Thanks for all the advice everyone! Flywheel end is # 1 Bearing,, Fan end is #8 Agreed. Rob’s project also has a leaky #8 o-ring sealing problem (separate post) in addition to this leak on #1 end that is really a leaking crankshaft galley plug. Oh dear..away you go ,I can offer the best luck I have and can give you. |
Robarabian |
Oct 20 2022, 10:21 PM
Thank you to all for the "Luck".. it must have worked.
I got the plug out. Carbide tip bits, drilled, tapped, heated the crank to expand it a bit and a slide hammer. I havent taken a photo yet cause I am still breathing hard from the experience. Tomorrow I go to International Metal Supply in Burbank and source some aluminum round stock to make the next plug. It will be a similar route, freeze the plug once fabricated and sized to shrink it a bit and then tap it in with wicking loctite. I have to make the plug as the mouth of the opening is just over 7mm and there is a slight taper down to 6.88 mm. So some fitting will be necessary but according to a Porsche engine guru who was nice enough to advise me, the aluminum dowel is the preferred way to go. This motor will be rebuilt in the future, I am just still enjoying it till that time comes. I have a 2.4 with triple webers and E cams that may get swapped into the car while this one goes through that process. I do like the drivability of the CIS. The VR seal is coming out as well, and I have a new Erring seal to put in its place so I am confident it will seal up. The #8 bearing will be a fix with Tom Amon's bearing seal kit not using JB weld, but another sealant. This will button it up for now. Finally it will get the tins painted, the fiberglass shroud repainted, new gaskets for the triangle of death and the IMS cover and new oil cooler seals. There isn't much else to leak at this point. I ll photo it when it's done. New clutch arrived as well so my confidence level is back up to "moderately high".... The World is great and I appreciate the advice within. Thank you all, truly. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:25 PM |
