New 2.8 Liter Six for the Racecar, I'll be asking a bunch of Conversion Questions |
motorvated |
Oct 21 2022, 03:28 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
The first question I have is related to modifications to the engine shelf pieces required for the 6-cylinder conversion. I noticed the Patrick Motorsports sells an expensive engine shelf kit for the 6-cylinder conversion. But, since the 6-cylinder is going into a Racecar, can I just cut out the entire engine shelf to maximize the available space in the engine compartment? Or, has anyone made a template that can be used to modify the 4-cylinder engine shelf to accommodate the 911 engines? I'd like just to remove the shelf parts if they are not needed. Thoughts on this? How do you other racers handle this. Many more questions to follow. I know there are many conversion threads out there, but it's hard to weed through them to see if they address the question(s) that I have. Plus most of Tigre are for street car conversions, not race cars.
Mike S. |
BillJ |
Oct 23 2022, 09:39 AM
Senior Member Group: Members Posts: 1,096 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Many go with JB Racings distributor. Jbracing.com
motorvated |
Oct 23 2022, 12:01 PM
brant |
Oct 24 2022, 10:06 AM
914 Wizard Group: Members Posts: 11,623 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Many go with JB Racings distributor. Jbracing.com JB Racing distributors look like they are just what I'm after. Since I do not yet know much about these 911 motors, does the distributor rotate counterclockwise? they will sell you one either direction of rotation depending on the crank/distributor gear you are running. I also use this distributor.. but build the motor with a 3.0 distributor gear for rotation |
Lo-Fi Version | Time is now: 11th May 2024 - 08:53 PM |
