New 2.8 Liter Six for the Racecar, I'll be asking a bunch of Conversion Questions |
motorvated |
Oct 21 2022, 03:28 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
The first question I have is related to modifications to the engine shelf pieces required for the 6-cylinder conversion. I noticed the Patrick Motorsports sells an expensive engine shelf kit for the 6-cylinder conversion. But, since the 6-cylinder is going into a Racecar, can I just cut out the entire engine shelf to maximize the available space in the engine compartment? Or, has anyone made a template that can be used to modify the 4-cylinder engine shelf to accommodate the 911 engines? I'd like just to remove the shelf parts if they are not needed. Thoughts on this? How do you other racers handle this. Many more questions to follow. I know there are many conversion threads out there, but it's hard to weed through them to see if they address the question(s) that I have. Plus most of Tigre are for street car conversions, not race cars.
Mike S. |
BillJ |
Oct 23 2022, 05:50 PM
Senior Member Group: Members Posts: 1,096 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Depending on where you want to drive the car be careful about what you cut out. Many vintage groups will not let you run with the trunk cut for example. Read the rules of where you want to race if that is your goal.
You should also consider the stock location and style for the oil tank. I have run in the front as well on a conversion car I owned in the past. |
infraredcalvin |
Oct 30 2022, 01:31 PM
Distracted Member Group: Members Posts: 1,513 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
You should also consider the stock location and style for the oil tank. I have run in the front as well on a conversion car I owned in the past. (IMG:style_emoticons/default/agree.gif) Both my cars use stock -6 oil tank. Even though I’m already plumbed to the front for cooling, the stock location is already engineered and keep things neat and clean. |
motorvated |
Oct 31 2022, 08:25 PM
You should also consider the stock location and style for the oil tank. I have run in the front as well on a conversion car I owned in the past. (IMG:style_emoticons/default/agree.gif) Both my cars use stock -6 oil tank. Even though I’m already plumbed to the front for cooling, the stock location is already engineered and keep things neat and clean. So if running a front oil cooler, the stock 914-6 oil tank has enough capacity to feed a 2.8 liter motor, or should I go for a larger capacity tank. I would like to mount the tank in the engine bay and not up front, and actually I'd like to run the stock oil cooler and maybe an additional cooler out back and not cut holes up front and run long oil lines up front and back. But I'm thinking that there may be no way around installing a front mounted oil cooler on a race motor. |
Lo-Fi Version | Time is now: 11th May 2024 - 09:04 PM |
